Old 07-11-2020, 08:19 PM   #1
Boog
laying low
Boog's Avatar
Accessory brackets
I bought all the engine bracketry off a 75 Blazer with 350 engine to mount the ac compressor and power steering pump. Or so I thought. Apparently I am missing another piece that bolts to the back of the pump. Here are a couple pics of what I have installed. Can any one tell me what’s missing and maybe send me a pic of the piece? I’d much appreciate it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-11-2020, 09:11 PM   #2
TXGREMLIN
Re: Accessory brackets
it looks like you need the other piece of the bracket.
its the one here behind the pump
TXGREMLIN is offline   Reply With Quote
Old 07-11-2020, 10:38 PM   #3
Boog
laying low
Boog's Avatar
That looks like one sold by the header maker. With stock manifolds I will need a stock bracket. Thank you Tx.
Anyone else have a pic of the stock piece?
Boog
primer is finer
Old 07-12-2020, 11:09 AM   #4
TXGREMLIN
I think I found it
Old 07-12-2020, 12:38 PM   #5
Boog
laying low
Boog's Avatar
That one is for non a/c. I am finding there were a half dozen or more different brackets from factory depending on application and yr models.
I believe for the 75-85 year engines I need this bigger bracket for my power steering and a/c setup. This was gone from the engine I got the other brackets from. I am now narrowing down the yr model and image to look for that bracket. I think another visit to the jy is in order now that I have a better idea of what I am looking for.
Thanks for the help.
Boog
primer is finer
Old 07-16-2020, 11:09 PM   #6
SilverMiner
SilverMiner's Avatar
That one is for non a/c. I am finding there were a half dozen or more different brackets from factory depending on application and yr models...
Boog - you mentioned in your original post you bought the parts from a 1975. I'm not certain what year vehicle you are attempting to install to. Your pictures show a short R4 compressor but the 1975 brackets you purchased would have been for the long log A6 Harrison compressor.
Which one are you attempting to achieve?
I've attached the diagram for an A6 installation and brackets from the GM factory manual. If you need to accommodate a different compressor you need to consult the correct year manual which are available here in PDF form after searching.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 07-17-2020, 04:28 PM   #7
Axle
Axle's Avatar
That is the style of bracket on my '81 with the r4 compressor ("pancake" compressor in case I got the naming wrong).
Alex.
Axle is offline   Reply With Quote
