Re: Project: Recycle
Ready to see all that go together. What shorty tilt you picking up? Rebuilt OE or aftermarket? Only thing I wish I would have done when I did a rebuilt/shortened was get one with wheel lock....
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
I have what I believe is an old van tilt column from ~30yrs back. Not sure if I'll utilize it & modify length as needed or if I'll drop the coin by hitting the EASY button for a new Ididit column. At $1k for the Ididit…. I'll need to put some thought into the decision as I'd rather use that money toward improving other stuff.
