Old 07-04-2020, 06:53 PM   #1
aknovaman
Cool Simplest DBW cruise control wiring
https://www.youtube.com/watch?v=XUIEzcq-ZFQ
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 07-05-2020, 12:54 AM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Simplest DBW cruise control wiring
If you have a factory or repro cruise control then you can just simply connect those 3 wires to the switch...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-05-2020, 05:44 PM   #3
First c10
First c10's Avatar
Gen III Only
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-07-2020, 09:00 PM   #4
87chevy.com
Just did a 2006 with the same tac module as you show and the diagram pretty much matches the exact same switches you have. Customer didnt care about cruise but schematics seem like nothing special. What is different with your momentary toggle switch vs a stock cruise switch
Old 07-07-2020, 09:55 PM   #5
aknovaman
My switches cost under $10 so its cheap, easy and clean. it just does not look factory. i generally put the switches very low on the driver side of the dash to semi-hide them but they are still reachable when driving. They can be put inside the center console too but not a reachable. Depending on what factory switch/column you use, the switching logic can be backwards. i.e. pressing the button opens the circuit rather than closing the circuit to apply 12 volts to the TACC. There is a huge writeup on this forum talking about how to use a relay to change the voltage(logic levels) for a mid-80's square body column.
here is a link to it.
http://67-72chevytrucks.com/vboard/s...d.php?t=398006
FMCDH GBU and GBA
Old 07-13-2020, 09:58 PM   #6
truckdude239
truckdude239's Avatar
Where do I find these switchs I'd like to do this on my c10
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-13-2020, 10:16 PM   #7
truckdude239
Nm I found some on amazon on off on momentary and a on off regulator switxh
David fuller
2000 Tahoe 5.3l 378
Old 07-13-2020, 10:42 PM   #8
aknovaman
I got a pack of 10 for about $15 on flea bay. They sell both kinds.
FMCDH GBU and GBA
