Old 07-07-2020, 07:32 AM   #1
CG
BlahBlahBlah
Big Block Serpentine?
Is there a budget way to put serpentine belt system with a big block that has air and power steering?
I dont want to spend the money on one of the fancy aftermarket systems.
Old 07-07-2020, 08:47 AM   #2
Lee H
Lee H's Avatar
Re: Big Block Serpentine?
How about a serpentine system off a mid 90s Chevy truck? Lots of folks, including me, have done this for small blocks, it’s cheap and easy. Should work for your big block also. If you find a big block truck in the wrecking yard and decide to go that route get everything, all the little brackets, fasteners..... the serpentine systems are reverse flow from stock so you will need the correct water pump and clutch fan.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-07-2020, 12:22 PM   #3
kyc10
Kwik Performance has brackets to install small block serpentine kit on big block
kyc10 is offline   Reply With Quote
Old 07-08-2020, 09:36 AM   #4
SCOTI
SCOTI's Avatar
x2.
I used the KWIK Perf adapters to allow using the 88-95 SBC/4.3 serpentine set-up on a BBC. The only thing additional I needed was a water pump pulley spacer for improved (for me) alignment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-08-2020, 01:24 PM   #5
MARKDTN
Didn't the last TBI 454 trucks/Suburbans have a serpentine setup?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-08-2020, 04:26 PM   #6
weq92f
weq92f's Avatar
GM still sells their cast iron system for the BBC right at 1500 includes all the accessories too a/c, ps, alt, wp ...
https://www.summitracing.com/tx/parts/nal-19417728
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-08-2020, 04:54 PM   #7
SCOTI
SCOTI's Avatar
-klb
Yes, the BBC TBI trucks had their own serpentine set-up. But, it's not as common nor compact as the SBC set-up.
That was the driving influence for me behind using the sbc serp set-up & adapters. Cheaper, easier to source, lighter, & cleaner/closer (tighter) to the motor vs. the BBC set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2020, 05:27 PM   #8
CG
BlahBlahBlah
-klb
Thats a good find. It just adds up to way more than I want to spend. I was just thinking while I have the nose off and am doing a little clean up I would look in to it.
I had someone reach out to me with most of the parts Ill need. Just need to crunch the numbers and see if its the way I want to go.
Old 07-08-2020, 08:00 PM   #9
BigBird05
I picked up a SBC serpentine set up for $50.00 Get one for a 5.7 and not a 4.3 and save your self a lot of trouble.
BigBird05 is offline   Reply With Quote
Old 07-08-2020, 11:43 PM   #10
SCOTI
SCOTI's Avatar
Why?
My set-up is technically off an S10 Blazers 4.3. Curious as the only difference I knew of was type of brackets (varied depending on year) & if they were equipped with or w/o a smog pump.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-11-2020, 01:54 PM   #11
CG
BlahBlahBlah
A member that has most of the parts I need reached out to me. All the brackets, New AC compressor, belt. I talked to Randy500 about it and he believed it to be a decent deal so I pulled the trigger with the member.
I have two pieces to order from kwikperformance and Ill need a reverse flow water pump for BB Chevy (which sorta sucks because I just bought a new stock AC Delco water pump). It was also mentioned I may need to change up the fan. Something Ill have to look in to.
Old 07-11-2020, 02:04 PM   #12
SCOTI
SCOTI's Avatar
You will need a reverse rotation fan. I measured my shroud & was able to get a slightly larger OD fan from Derale Cooling.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-11-2020, 02:06 PM   #13
CG
BlahBlahBlah
Ok that makes sense now that you said that. Thank You!
Old 07-11-2020, 11:25 PM   #14
weq92f
weq92f's Avatar
I have some parts you may find useful from my conversion to electric fans... leftover was the rigid fan, spacer+bolts...
It is a reverse rotation fan.
EDIT: free of charge if you can use it CG
-klb
Old 07-14-2020, 01:03 PM   #15
Doug's68SS
I used the KWIK Perf adapters alsoName:  CD.jpg
Doug's68SS is offline   Reply With Quote
Old 07-14-2020, 02:44 PM   #16
SCOTI
SCOTI's Avatar
Originally Posted by Doug's68SS View Post
I used the KWIK Perf adapters alsoAttachment 2032865
Attachment 2032866
Curious.... How was the alignment on your water pump pulley? Was it centered on the belt?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
