#23 |
Re: 59 billet hood hinges
Slight update with my Eddie Motorsports hinges. I have been busy with other stuff. But I did a little searching online for a solution. Here is what I found.
55.5-57 cabs use a 3/8" bolt to attach the hinge to the firewall. The vertical spacing is also closer together than 58-59 (I already knew that 2nd part) 58-59 cabs use a 5/16" bolt to attach the hinge to the firewall. The vertical spacing is farther apart than the 55.5-57 cabs. You can re-use the top hole. But the threaded insert will not be for the correct size bolt. I have a 56 cab that I already drilled the new lower hinge hole, because I tried LMC hinges and I feel that they really suck. That's why I went with the EMS hinges. I ordered EMS hinges for a 58-59 because I wanted to ensure they were correct for that hood. That is why the 58-59 EMS hinge is not slotted for a 3/8 bolt because a 58-59 would have used a 5/16 bolt. So long story short, I am going to use 5/16 bolts. I may end up buying longer ones for the hinge to attach to the firewall. I also will probably cut off the square nuts off the firewall and weld on some new ones that are threaded for 5/16. Now I just need to get some motivation. I'm a head custodian for a Jr. High near Chicago. School starts in 4 weeks and my mind is racing on lots of things lately. |
| Bookmarks |
