Old 07-12-2020, 12:20 AM   #1326
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today.The 3rd chapter
Cleaned up and ready to cruise to a show about an hour and a half away with 3 or 4 other trucks.. first good trip of 2020 for me
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 07-13-2020, 12:01 PM   #1327
Happy_dan
Happy_dan's Avatar
Started to work on removing corrosion and cleaning up the original wheels. In case I actually decide to use them. I finished getting all 5 and the friction rings cleaned up and in primer. Waiting on flaps to arrive from Coker. Then I have to decide if I actually want to use them.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 07-17-2020, 09:36 PM   #1328
countr
countr's Avatar
Installed my tires, wheels and caps on the 67 4x4
Thanks Russ
countr is offline   Reply With Quote
Old 07-17-2020, 10:13 PM   #1329
gmc684x4
Going through an engine my son and i pulled last weekend strong runner was rebuilt a year or two before the truck it was in was wrecked got it on a stand cleaning getting it ready for fresh paint and gaskets
gmc684x4 is offline   Reply With Quote
Old 07-18-2020, 12:46 AM   #1330
OregonNed
OregonNed's Avatar
Clean up after the only car show I will attend this year (due to Covid) Took a pic before garaging it again.
Old 07-18-2020, 01:00 AM   #1331
Greasey Harley
Greasey Harley's Avatar
Drove the darn thing.
First time in several months!!!!
...Then I did a big fat burnout in that parking lot right there
Greasey Harley is offline   Reply With Quote
Old 07-18-2020, 04:05 AM   #1332
OregonNed
OregonNed's Avatar
Nice! One of my current "wants" are slotted wheels like you have. They look great!
Old 07-18-2020, 09:58 AM   #1333
SRU1436
Changed the accelerator pump, spring and air horn gasket on the Quadra jet. It eliminated the slight bog in the beginning of the throttle.
SRU1436 is offline   Reply With Quote
Old 07-18-2020, 05:14 PM   #1334
ohboy321
ohboy321's Avatar
I siphoned about 15 gallons of old gas out of my tank. For reasons out of my control the fuel will be 2 years old by the time I get it running again this fall. Pulled the sending unit and it looks like it is fairly new. Also pulled a stick out of the tank....must have been kids.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 07-20-2020, 01:01 PM   #1335
Indyuke
Cleaned up and converted the old oil bath air cleaner to paper element.
Indyuke is offline   Reply With Quote
Old 07-21-2020, 12:58 PM   #1336
Boog
laying low
Boog's Avatar
The stick could have been used to check gas level if the gauge quit working.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-21-2020, 01:03 PM   #1337
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I used to use a yardstick for my gauge....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-21-2020, 02:06 PM   #1338
Boog
laying low
Boog's Avatar
A lot of us have.
Boog
primer is finer
Old 07-21-2020, 02:12 PM   #1339
ohboy321
ohboy321's Avatar
Before I put the sending unit back in I pulled out a valve stem cap....would love to know the story on how it got there.
Steve/NH
Old 07-21-2020, 07:10 PM   #1340
bry593
1. Blasted and painted a set of horns I got from Danny. Installed and annoyed my neighbors with glee.
2. Completed 1st oil and filter change on my GM crate HT383. Surprisingly little iron on the magnetic drain plug. Filled with 30w diesel oil and a wix filter. Used traveller brand from tractor supply. Next oil change will use 5w30 synthetic.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 07-21-2020, 10:22 PM   #1341
Steeveedee
Who Changed This?
Steeveedee's Avatar
Might be a story like how one of my little sisters at about the age of 5 thought it would be nice to play "gas station", and put the garden hose into the gas tank of my dad's truck and fill it up! Not to mention the rocks and dirt.
~Steven
Simi Valley, CA
Old 07-22-2020, 12:48 PM   #1342
Happy_dan
Happy_dan's Avatar
Thanks Russ
I am very jealous of this! I wish I could just get the tires mounted on mine. No one wants to touch the friction ring wheels. I am calling another company today that deals with tractor trailers. They said the old timer that does them was on vacation last rime I called.
Old 07-22-2020, 01:42 PM   #1343
67C10Step
67C10Step's Avatar
New cab bushings installed. Nothing torqued to spec yet because I have it up on jack stands with the entire front end out. Want to wait until I get it back on the ground to line it all up.
Wire wheeling, blasting, and painting A frames and stuff waiting on my disc brake kit with drop spindles to arrive.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-23-2020, 02:25 PM   #1344
greekoneaz
Actually what i did on my truck...1st time in 15 years
dropped my tank and removed the FP, ordered a new tank and sending unit
random rocks and sand in the old tank... might be original stamping says USS with 12 7 66 date
greekoneaz is offline   Reply With Quote
Old 07-25-2020, 01:54 PM   #1345
basketcase
basketcase's Avatar
Working on the wiring. I'm re-routing it so it's out of sight for the most part. That requires lengthening and some new connectors. Since most of my harnesses are in good shape and still pliable I might as well use them instead of buying new harnesses and cutting them up to lengthen. Also installed a relay harness for the headlights.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 07-26-2020, 12:13 PM   #1346
CryingJoker
Started cleaning on a set of GM transport wheels I recently picked up cheap. Decided since 1 was more faded than the others they needed a touch up while I waited on tires to ship. And figured why not change it a little from normal black or white. Painted dodge granite crystal on a gamble and I'm digging the results so far. Think I did fairly well first time trying to clear coat wheels.
20200725_155739 by James Williams, on Flickr
20200725_155751 by James Williams, on Flickr
03 s-10: daily driver
94 s-10: late model toy
70 c10: starting frame off resto
80 c10: for sale just collecting dust
94 c1500: hauler to and from
55 chevy: hot rod project jus reborn
CryingJoker is offline   Reply With Quote
Old 07-26-2020, 12:45 PM   #1347
Ol Blue K20
They look good. I may paint the rally's on my Elkie that color.
Dale
Old 07-26-2020, 04:04 PM   #1348
tdangle
tdangle's Avatar
Finished going thru the hydraulic system for my 4 wheel drum brakes. Did the rears couple of weeks ago. No issues except a lot of moisture and crud in the wheel cylinders and a worn star wheel on the adjuster. Finally got to the front ones yesterday. No leaking and really in good shape inside, no moisture that I could determine. But what a pain getting the wheel cylinders off. the bolts are almost behind the spindle frame. And looks like the drums are close to end of life. Linings like like new hoses are date coded 12-31-01 and in pretty good shape. Looking into a disc brake upgrade.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-26-2020, 08:44 PM   #1349
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Drove it down the road to pickup some corn for dinner. Corn is sold roadside on the honor system. Sunflowers are starting to bloom.
Old 07-26-2020, 09:47 PM   #1350
Steeveedee
Who Changed This?
Steeveedee's Avatar
That sure as shootin' ain't California! You'd find no corn, no money, no table, no shade and no cash box around here. And they'd probably throw the cabbage at passing cars. Of course, my nice little corner here, we just have crack heads.
~Steven
Simi Valley, CA
