Old 06-25-2004, 01:02 AM   #1
skokie
skokie's Avatar
Power Drain
I havent started the truck in a week and a half. I go out and turn the key nada. Put my multimeter on the battery and guess what 9.25 instead of 12. Put the charger on for an hour and a half and he fires right up. I saw the faq regaridng key drains. I unplugged everything from the fuse box except for the fuel sending unit. Is there anything else that I could try?
skokie is offline   Reply With Quote
Old 06-26-2004, 02:39 AM   #2
skokie
skokie's Avatar
To the top
Old 06-26-2004, 03:06 AM   #3
krue
Designated A-hole!
krue's Avatar
With everything unplugged are you still getting the drain?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-26-2004, 08:27 PM   #4
franko72
Franko72
franko72's Avatar
sounds like a bad battery. put a charge on it and take a reading after the charge cycle.How old is the battery?reconnect the battery and start the engine and get a reading of your charging circuit.If both are OK you will have to pull fuses one at a time to check for shorts in the circuits at the fuse block.could be a voltage regulator or an alternator not completing the charge pattern also. sounds like an old battery that needs replaced.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 06-26-2004, 08:35 PM   #5
RON WOODGEARD
Resident Young Old Dude !
There's a Diode inside the alternator that occassionally goes bad, It will charge in a normal manner, everything does what it's supposed to do ( charge well) then it drains the battery when the key is off..
You can do somewhat a test at home without diagnostic equipment, Just charge the battery then Unplug all wires from the alternator and let it set a few days. But it's faster and free to have it checked.
RON WOODGEARD is offline   Reply With Quote
Old 06-26-2004, 10:52 PM   #6
skokie
skokie's Avatar
Krue: Yes everything is unplugged from the fuse box minus the fuses. I will try unplugging the alternator.get a reading and then check again tomorrow and see what happens. I will post back what I find.
Old 06-26-2004, 10:59 PM   #7
thisolechevy
Why not just unplug the +pos. cable on the battery when you store it? I do minew every time it goes into storage for more than a couple weeks.
BUT it definetly is a good idea to figure out why it drains.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 06-27-2004, 09:28 AM   #8
Blue Beard
Blue Beard's Avatar
Have the same issue, checked all the wiring seems to be right.
Net will be the alternator.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 06-27-2004, 01:29 PM   #9
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Try checking the fusible links at the front of the engine compartment, they're in small black fuse holders. One is hooked up to a junction box on the passenger fender, and the other one is in almost the same spot on the drivers side. There's a really small 5 amp fuse in both of 'em. Not sure if that's the problem, but it's good to check 'em anyway.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-27-2004, 03:38 PM   #10
cableguy0
unhook the positve cable put one lead of your voltmeter on the battery the other end on the battery cable it will read a voltage have a buddy start pulling fuses until the draw goes away it will read very low when you find the problem like well under .5 a volt. that test will get you looking in the right spot just check everything on the circuit that that particular fuse controls
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-27-2004, 09:47 PM   #11
krue
Designated A-hole!
krue's Avatar
It just so happens that I am going to have to do this now, since I have found that I have a key off drain since I put my engine back in the truck.
www.daveramsey.com
Old 06-28-2004, 04:44 AM   #12
krue
Designated A-hole!
krue's Avatar
Found mine, it's the positive cable.
www.daveramsey.com
Old 06-28-2004, 07:38 PM   #13
skokie
skokie's Avatar
Bad cable hu? HMM. Maybe I will change mine out.
Old 06-28-2004, 08:47 PM   #14
krue
Designated A-hole!
krue's Avatar
Got against the manifold.
www.daveramsey.com
Old 06-28-2004, 09:02 PM   #15
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
when i put my motor in i switched to a (used) newer style internally regulated alternator and put an electric fan on it. i got a key off drain about two weeks later. i took my alternator in to autozone and they said it was fine. so i figured my battery just wasnt holding a charge anymore so i went out and con-ed the guy at the auto parts store to exchange my 3 year old optima for a new one (only a 1 year warrenty), killed my new battery. after 3 days of chasing wires i took it to a shop. my alternator that autozone said was fine wasnt. it charged fine, but it had a key off drain. the electric fan burnt the diaod up. so new 80 amp(i think) alternator, no problems.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
