10-18-2019, 11:07 PM | #1 |
Installation / Mounting instructions for 1972 DG4 mirrors
Does anyone have a better picture / pdf of the mounting instructions for the 72 DG4 mirrors? And.............what manual are these instructions in?
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
10-19-2019, 09:59 AM | #2 |
20' Daredevil (Ret)
Re: Installation / Mounting instructions for 1972 DG4 mirrors
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-18-2020, 07:57 PM | #3 |
Anyone have a clearer picture of the mounting instructions? I'm having difficulty reading the dimensions for the DG4 location.
Thank you!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
07-18-2020, 11:43 PM | #4 | |
The Older Generation
I looked in the Factory Assembly Manual but didn't see anything about the DG4's. The illustration you posted must have come from the Chassis Service Manual and the only one of those I have in the house is for '67. LockDoc
07-19-2020, 03:04 AM | #5 |
Never seen that page, not in the service or assembly manual. Can measure mine as it had original DG4 type mirrors.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
07-19-2020, 09:42 AM | #6 |
Thanks Richard. Need the dimensions as shown from door leading edge to top and bottom mounting holes.
I think the screws are 1/4-14 SS sheet metal screws to fit 3/16 drilled holes. At least that is what I am seeing in the picture.
07-20-2020, 04:52 PM | #7 |
I bumped this thread back to the top today. It suggests a couple of different measurements. http://67-72chevytrucks.com/vboard/s...d.php?t=800535 LockDoc
07-21-2020, 02:05 AM | #8 |
The thread Lockdoc pointed out has good info. Did not visit my truck until today. My truck orginally had the painted DG4 (D29) The holes are small because they were welded up in drivers door and re-drilled before paint. I will be installing the rivit nuts pointed out in the other thread. Holes were still in my old passenger skin I kept. I verified driver and passenger mirror locations are the same.
07-21-2020, 12:43 PM | #9 |
Thanks Richard. Danny also sent some pics. I uploaded to the gallery, but can't seem to post pics directly to this thread. So here are the links:
https://67-72chevytrucks.com/gallery...hp?photo=46861 https://67-72chevytrucks.com/gallery...hp?photo=46862 Based on your pics and comparing to what I can sort of read from the OE instructions, I'd venture this is the original intent: *Drill (3) 0.19" (3/16) holes thru *Top hole is 8.25" (8-1/4) back from leading edge of door. *Bottom forward hole is 5.81" (5-13/16) back from leading edge and down about 6.13" (6-1/8) from body line. *Fasten to door with (3) #14-14 x 3/4, stainless steel hex washer head or Philips pan head screws. I plan to seal the screw holes by placing a small blob of butyl rubber on each hole and putting the screw thru the center of it. This is the same butyl "ribbon" used to seal front and rear windshields in 1970's GM cars. Should work fine.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 07-21-2020 at 01:10 PM. |
07-21-2020, 01:06 PM | #10 |
The OE elbows are chrome plated steel and are usually pitted. LockDoc shared a thread with some possible aftermarket alternatives for both elbows and mirrors:
Elbows, 4.5” even offset Signal Stat 7933 Truck lite 97869 Napa LIT 97869 Mirrors Truck lite 97805 Signal Stat 7053 Other part numbers 97842 97681 By the way, all of the hardware can be found at http://www.boltdepot.com, and costs about $25 shipped. Needed to rebuild one pair of mirrors: *(8) Nylon Washers - .406 x .94 x .06 *(10) SS Plain Washers - .406 x .88 x .06 (Varies depending on washer thickness and stud length) *(4) SS Lockwashers - .406 split *(4) SS Acorn Nuts - 3/8-16 UNC *(6) SS Washer Head Screws - #14-14 x 3/4 with .515 washer *(6) SS Internal Tooth Lockwashers - .281 ID (if you want to use under attachment screws, but probably not necessary)
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 07-21-2020 at 02:10 PM. |
