Old 07-22-2020, 05:28 PM   #4
Beach-Burban
Beach-Burban's Avatar
Re: Need some help.....3rd door lock
Originally Posted by FLYNAVY30 View Post
Well, after much cussing, and fishing dropped parts out of the door, I got it back together. I found the easiest way was to use a magnetic pick up tool to hold the clip in place over the arm on the lack mechanism....then gently push the end of the popper through the assembly. Once that was in place, it took some finesse, but I was finally able to rotate the clip up 90 degrees to snap it in place on the shaft of the popper. What a PITA....the two front doors are significantly easier to access.
Glad you got it together, Greg...I would have been of no help to you on this one, even though I recently worked on the 3rd door mechanism while getting my key cylinder operational. Luckily for me, mine stayed together so a little lube was all the popper arm needed on that end. It is really deep in there, I'll have to admit!
Woody
Beach-Burban is online now   Reply With Quote
