Old 07-13-2020, 10:01 AM   #1276
Rickysnickers
Re: 53 Surburban "Family Truckster"
Impressive work!! I meant to ask, what kind of undercoating did you use on your fenders and running boards? Thanks in advance.
Old 07-13-2020, 10:25 AM   #1277
youngrodder
youngrodder's Avatar
Originally Posted by oldman3 View Post
Marc, looks great...Jim
Thanks Jim
Thank you. I used Rapor Liner
https://www.autozone.com/paint-and-b...E&gclsrc=aw.ds
i used a total of 8 bottles (2 kits) on my Suburban body (top and bottom of floors) and firewall. Including all fenders and body parts.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 07-13-2020, 12:09 PM   #1278
joedoh
joedoh's Avatar
man you have the patina thing locked up.
Old 07-13-2020, 12:19 PM   #1279
mongocanfly
mongocanfly's Avatar
Looks great Marc..!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-13-2020, 01:06 PM   #1280
youngrodder
Thxs, I'm trying. I keep learning the more I do. From the doors now I'm going to redo some of the body. I'm not happy with parts of the body now after seeing how the doors turned out.
Originally Posted by mongocanfly View Post
Looks great Marc..!
Thanks Greg
Marc
Old 07-14-2020, 04:54 AM   #1281
84blaze
Marc, Do you plan to install power windows?
84blaze is offline   Reply With Quote
Old 07-14-2020, 07:51 AM   #1282
youngrodder
Not in this one...My 48 had everything electric, including the fresh air vent. If you want power windows go with Nu-relic. They are not cheap but quality never is. They are direct bolt in and work great.
Marc
Old 07-15-2020, 04:09 AM   #1283
84blaze
Originally Posted by youngrodder View Post
Not in this one...My 48 had everything electric, including the fresh air vent. If you want power windows go with Nu-relic. They are not cheap but quality never is. The are a direct bolt in and work great.
Marc
Right on. Those are the ones I have earmarked for my build.
Old 07-15-2020, 08:58 AM   #1284
youngrodder
Good deal. I didn't care for their switches so I went with some from a another supplier.
https://watsons-streetworks.com/prod...gory/switches/
Marc
Old 07-16-2020, 03:18 AM   #1285
84blaze
Marc
I plan to use their NU-cranks so I can keep it looking like it has manual windows.
https://www.nu-relics.com/product-p/233.htm
How did you run the wiring into the doors? I've seen those contacts that fit in the door jams and think they look like a clean option.
https://www.keepitcleanwiring.com/ca...et-(3-Contacts)
Old 07-16-2020, 08:39 AM   #1286
youngrodder
That's exactly what I used. I think I used 4 contacts as I also had power door actuators for my shaved handles to power as well....It worked fine.
Old 07-17-2020, 07:32 AM   #1287
reaper71
reaper71's Avatar
84blaze, keep it clean is part of the hoffman group (A.K.A Autoloc) in my experience using parts from any of these companies is very cheap and not reliable.
just my 2 cents.
I'd use watsons anyday over a hoffman group co.
Mark.
reaper71 is offline   Reply With Quote
Old 07-17-2020, 08:23 AM   #1288
youngrodder
just my 2 cents.
Mark.
I agree with Mark. I should have been more specific. I didn't get those door contacts from "Keep it Clean". I would never buy anything from Hoffman Group. I have bought several things from Watson's and they have always been great quality.
Marc
Old 07-18-2020, 01:47 AM   #1289
ajgriffin
ajgriffin's Avatar
Hey Marc (and anyone who knows better than me), did you happen to use an ARP balancer bolt? I was putting mine together today and noticed that the directions from ARP and ATI don't agree with each other (different torque and loctite vs ARP assembly lube). Curious to know what you ended up doing.
Also, you probably already caught this, but I didn't The instructions also say that the alternator grounds through the water pump housing so it says to keep that mounting surface paint free. Not sure if it matters much or not, but I went back and cleaned that area of my block since I didn't mask it off before paint
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 07-18-2020, 11:47 AM   #1290
youngrodder
Attachment 2033623
Attachment 2033624
I used an ARP bolt. I didn't realize that the Holley kit came with one. I think I used the lube that came with the bolt. Not sure on the torque specs (it was a few months ago). My mechanic friend torqued everything. My block is all Aluminum. I did go back after I removed the tape and grounds away the paint from the mating surfaces. I should be good. I did notice that black paint is removed from the bolt journals on the water pump. To allow for proper grounding must be why...Good looking out.
Marc
Old 07-19-2020, 10:43 PM   #1291
youngrodder
Just about have the exhaust finished up. We really just have the tail pipes and rear hanger/mounts to figure out. My friend Josh that is the fabricator at my friends rod shop is so incredible talented. No way this exhaust turns out 1/2 as nice without Josh...Pics are deceiving, My air lines are no where close to the pipes. I added 90 degree air fittings and rerouted the lines to the top of the frame rail to offer more clearance. Tomorrow I will bolt up the front section of the exhaust for the last time. I had to drill and tap the tranny mount as we we have some clean mounts the bolt up to that.
I also repainted the body. As I mentioned after seeing how my doors turned out I didn't like the body. It looked too fake to me. I added more air brush work the second time around. I'm much happier with it. Pics on that later.
Here is where we are with the exhaust.
Marc
Old 07-20-2020, 08:09 AM   #1292
8man
Those are a work of art.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-20-2020, 09:29 AM   #1293
youngrodder
Thanks, he does great work. Here is another example of exhaust Josh did on a 70 Nova. This exhaust was 3" and the tubes were oval in shape for added ground clearance. This picture was prior to finishing all of the way to the tail pipes.
Marc
Old 07-24-2020, 10:26 PM   #1294
youngrodder
As I wait for my buddy to come finish my exhaust I figured I would work on some other random tasks. I dropped in my radiator to see how it fit My radiator support is original and in super shape. At first I left the cross bracing but I could tell that I need to remove them in order to fit my 4 core radiator. I also had to clearance the lower inside corners as my tanks hit. Now that I dropped that radiator in I can see if a Cooling Components fan/shroud will fit. I only have 2.25" clearance so I might need to get creative here.
I wanted to see how the cowl cover and hardware looked so I bolted that in place. I'm stoked to see some of these details that have been in my head come to reality..
I started to give my chrome grill a brushed finish to match the rest of my trim. It was too dark for an after pic so I will post pics tomorrow on that (teaser...see what I did there).
Lastly I made one of my transmission cooling lines. I need to pick up some more flex hose from Summit....
Old 07-25-2020, 12:08 PM   #1295
mongocanfly
Marc...that's looking great..!!...love the look of the countersink fender bolts..!!
What radiator are you running?.. I'm to lazy to go back and look..haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-25-2020, 05:51 PM   #1296
joedoh
joedoh's Avatar
sooooo clean
Old 07-26-2020, 10:09 AM   #1297
youngrodder
Thanks, I used them on my 48 truck I build. I really liked how they looked in the bed for the bolts to hold the rear fenders on. They look good and server a function of keeping the metal flat so its a win win. I'm using a Champion 4 core that I painted in epoxy black.
sooooo clean
Thanks man..
Marc
Old 07-26-2020, 10:21 AM   #1298
youngrodder
Sat....So I found I already had more flex hose so I finished making/installing my tranny lines. My friend came back and we are just about done with the exhaust. I also worked on pre assembling the vintage air set up.
Here are a couple pics of the brushed grill. I also installed my turn signals while I was at it. The more I can pre assemble now the quicker the final install will go.
Marc
Old 07-26-2020, 05:12 PM   #1299
mongocanfly
Oh man....that grill looks sooooooo good...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-26-2020, 11:32 PM   #1300
oldman3
oldman3's Avatar
Marc, nice job on the grill...Jim
oldman3 is offline   Reply With Quote
