07-12-2020, 12:20 AM | #1326 |
Re: What did you do to your truck today.The 3rd chapter
Cleaned up and ready to cruise to a show about an hour and a half away with 3 or 4 other trucks.. first good trip of 2020 for me
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-13-2020, 12:01 PM | #1327 |
Started to work on removing corrosion and cleaning up the original wheels. In case I actually decide to use them. I finished getting all 5 and the friction rings cleaned up and in primer. Waiting on flaps to arrive from Coker. Then I have to decide if I actually want to use them.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
07-17-2020, 09:36 PM | #1328 |
Installed my tires, wheels and caps on the 67 4x4
Thanks Russ |
07-17-2020, 10:13 PM | #1329 |
Going through an engine my son and i pulled last weekend strong runner was rebuilt a year or two before the truck it was in was wrecked got it on a stand cleaning getting it ready for fresh paint and gaskets
07-18-2020, 12:46 AM | #1330 |
Clean up after the only car show I will attend this year (due to Covid) Took a pic before garaging it again.
07-18-2020, 01:00 AM | #1331 |
Drove the darn thing.
First time in several months!!!! ...Then I did a big fat burnout in that parking lot right there |
07-18-2020, 04:05 AM | #1332 |
Nice! One of my current "wants" are slotted wheels like you have. They look great!
07-18-2020, 09:58 AM | #1333 |
Changed the accelerator pump, spring and air horn gasket on the Quadra jet. It eliminated the slight bog in the beginning of the throttle.
07-18-2020, 05:14 PM | #1334 |
I siphoned about 15 gallons of old gas out of my tank. For reasons out of my control the fuel will be 2 years old by the time I get it running again this fall. Pulled the sending unit and it looks like it is fairly new. Also pulled a stick out of the tank....must have been kids.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
07-20-2020, 01:01 PM | #1335 |
Cleaned up and converted the old oil bath air cleaner to paper element.
07-21-2020, 12:58 PM | #1336 | |
laying low
07-21-2020, 01:03 PM | #1337 |
Proprietor of Dale's Corner
I used to use a yardstick for my gauge....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-21-2020, 02:06 PM | #1338 |
laying low
A lot of us have.
07-21-2020, 02:12 PM | #1339 |
Before I put the sending unit back in I pulled out a valve stem cap....would love to know the story on how it got there.
07-21-2020, 07:10 PM | #1340 |
1. Blasted and painted a set of horns I got from Danny. Installed and annoyed my neighbors with glee.
2. Completed 1st oil and filter change on my GM crate HT383. Surprisingly little iron on the magnetic drain plug. Filled with 30w diesel oil and a wix filter. Used traveller brand from tractor supply. Next oil change will use 5w30 synthetic.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
07-21-2020, 10:22 PM | #1341 |
Who Changed This?
Might be a story like how one of my little sisters at about the age of 5 thought it would be nice to play "gas station", and put the garden hose into the gas tank of my dad's truck and fill it up! Not to mention the rocks and dirt.
07-22-2020, 12:48 PM | #1342 |
I am very jealous of this! I wish I could just get the tires mounted on mine. No one wants to touch the friction ring wheels. I am calling another company today that deals with tractor trailers. They said the old timer that does them was on vacation last rime I called.
07-22-2020, 01:42 PM | #1343 |
New cab bushings installed. Nothing torqued to spec yet because I have it up on jack stands with the entire front end out. Want to wait until I get it back on the ground to line it all up.
Wire wheeling, blasting, and painting A frames and stuff waiting on my disc brake kit with drop spindles to arrive.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
07-23-2020, 02:25 PM | #1344 |
Actually what i did on my truck...1st time in 15 years
dropped my tank and removed the FP, ordered a new tank and sending unit random rocks and sand in the old tank... might be original stamping says USS with 12 7 66 date |
07-25-2020, 01:54 PM | #1345 |
Working on the wiring. I'm re-routing it so it's out of sight for the most part. That requires lengthening and some new connectors. Since most of my harnesses are in good shape and still pliable I might as well use them instead of buying new harnesses and cutting them up to lengthen. Also installed a relay harness for the headlights.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
07-26-2020, 12:13 PM | #1346 |
Started cleaning on a set of GM transport wheels I recently picked up cheap. Decided since 1 was more faded than the others they needed a touch up while I waited on tires to ship. And figured why not change it a little from normal black or white. Painted dodge granite crystal on a gamble and I'm digging the results so far. Think I did fairly well first time trying to clear coat wheels.
20200725_155739 by James Williams, on Flickr 20200725_155751 by James Williams, on Flickr
03 s-10: daily driver 94 s-10: late model toy 70 c10: starting frame off resto 80 c10: for sale just collecting dust 94 c1500: hauler to and from 55 chevy: hot rod project jus reborn |
07-26-2020, 12:45 PM | #1347 |
They look good. I may paint the rally's on my Elkie that color.
07-26-2020, 04:04 PM | #1348 |
Finished going thru the hydraulic system for my 4 wheel drum brakes. Did the rears couple of weeks ago. No issues except a lot of moisture and crud in the wheel cylinders and a worn star wheel on the adjuster. Finally got to the front ones yesterday. No leaking and really in good shape inside, no moisture that I could determine. But what a pain getting the wheel cylinders off. the bolts are almost behind the spindle frame. And looks like the drums are close to end of life. Linings like like new hoses are date coded 12-31-01 and in pretty good shape. Looking into a disc brake upgrade.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-26-2020, 08:44 PM | #1349 |
Carpe manana
Drove it down the road to pickup some corn for dinner. Corn is sold roadside on the honor system. Sunflowers are starting to bloom.
07-26-2020, 09:47 PM | #1350 |
Who Changed This?
That sure as shootin' ain't California! You'd find no corn, no money, no table, no shade and no cash box around here. And they'd probably throw the cabbage at passing cars. Of course, my nice little corner here, we just have crack heads.
