Old 06-29-2004, 08:01 AM   #1
bestchevyfan
remove tailgate??????????????
I've disconnected the arms and I can't remove it from the trunnions.
How does that come off?
bestchevyfan is offline   Reply With Quote
Old 06-29-2004, 08:50 AM   #2
longhorn70gmc
longhorn70gmc's Avatar
Removing tailgate!
Hope this helps. Remove the two bolts in only one trunion and lift up on that side and it should come off. A word of caution. The bolts sometimes rust real bad and can cause problems. Example: anchor nut may fall off inside. Goodluck.
Longhorn70gmc
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 06-29-2004, 09:30 AM   #3
bestchevyfan
There is one bolt above and below the trunion but I can't get to the bottom one.
What do I have to remove to get to it? Tail light? Bumper?
Old 06-29-2004, 09:47 AM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Taking the bumper off will give you access to the lower bolt. Depending on the bumper type, you may also be able to get to it from underneath with a universal joint, extension and ratchet.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-29-2004, 09:57 AM   #5
damage
I'm not sure if mine are different from everyone elses, or someone put a new style cup, but one of mine is round, while the other is more like a horse shoe. When the Tailgate is at a 45 angle, I can give it a good pull on the one side and it pops right out. Looking at mine, i have enouph room on the bottom to get an air rachet in there, but thats probaly about it with the bumber on. Hope that helps...
damage is offline   Reply With Quote
