hood spring
the small coil spring that attaches to the front top deck of the core support that makes the hood pop up. How does it attach? does it somehow screw in the deck or snap into place. Confused. 1978 c10 thanks
Re: hood spring
Should snap on/ pop in place. Should be a little bump in the metal that the big side pop in to and hold it . If I remember right now been about 20 years sine I had my 77 rad support.
I hope this helps
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
