Old 07-27-2020, 07:02 AM   #1301
84blaze
Re: 53 Surburban "Family Truckster"
Marc, what's the process you're using to acheive the brushed look on your grill? I really like the look and I'm taking notes...
84blaze is offline   Reply With Quote
Old 07-27-2020, 07:58 AM   #1302
youngrodder
youngrodder's Avatar
Originally Posted by mongocanfly View Post
Oh man....that grill looks sooooooo good...
Thanks I'm digging it..
Originally Posted by oldman3 View Post
Marc, nice job on the grill...Jim
Thanks Jim
Just take a red scotch bright pad. I apply a little penetrating spray to the pad then use elbow grease. The key is to go the same direction with your strokes and keep the even lines. If you don't the grain of the metal will be messed up.I suggest starting on a junk piece first and practice. That's what I did.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 07-27-2020, 08:07 AM   #1303
youngrodder
We the exhaust got pretty much wrapped up this weekend. My fabricator friend had 31 hrs into this exhaust. keep in mind he would haul the pieces back to the shop to cut/fit/weld. All we have left is to add a hanger to the ends. I'm pretty pleased with how it turned out. It's not quite a full system but longer than a shorty system that ends under the body.
The body will go back on for good In about a week.
Thank you
Marc
Old 07-27-2020, 08:44 AM   #1304
oldman3
oldman3's Avatar
That's looking great, can't wait to see body on (I know you can't either)...Jim
oldman3 is offline   Reply With Quote
Old 07-27-2020, 08:46 AM   #1305
mongocanfly
mongocanfly's Avatar
Exhaust looks great..!....I'm ready for the body to go on to...!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-27-2020, 08:48 AM   #1306
8man
That's one good looking frame!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-27-2020, 08:54 AM   #1307
youngrodder
You know it Jim...ha ha. I have done a fair amount of pre-assmebly so I think it will go together swiftly.
Thanks, me too...
Thank you, it needs a good detailing before I drop the body back on.
Marc
Old 07-28-2020, 02:41 AM   #1308
ajgriffin
ajgriffin's Avatar
Coming together real nice Marc!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 07-28-2020, 11:58 PM   #1309
joedoh
joedoh's Avatar
beautiful attention to detail
Old 08-06-2020, 08:05 AM   #1310
youngrodder
Here's where were at. The exhaust is complete and fully bolted in (O2 sensors and all). This Sunday some buddies are coming over to help me drop the body on the chassis for the last time. I still need to detail/clean the frame before Sunday
In an effort to gain more radiator clearance I need about 5/8". Modifications were needed to the radiator and core support to gain some room. I use cooling components fans for a couple reasons. 1. they are a 2 speed fan that move some serious CFM's. 2. They come with a shroud. 3. They are quiet. They are not cheap but on my 48 it solved my overheating issues.
http://coolingcomponentsinc.us.com/p...ucts/cci-1770/
I did a similar modification on my 48 but this time around it was better executed. I notched the flange on the top of the core support to move the radiator forward. I then broke loose the welds and I will realign the mounting flange to be vertical. As you know they have a slant from the factory to lean the radiator back. My fabricator friend Josh will weld it back together. These mods should create the space I need.
While I was looking at things it became apparent that the top of the factory core support was ugly the way the ends terminated. So I trimmed them back some and capped them off...
Now for the bad news. Both my radiator and core support were already painted. Some touch up will be needed here.
Marc
Old 08-06-2020, 08:09 AM   #1311
youngrodder
More pics....
You can see from the exposed aluminum where the brackets used to be aligned. This is a few pics of the capped core support.
Marc
Old 08-06-2020, 08:58 AM   #1312
oldman3
oldman3's Avatar
Looking good Marc...Jim
Old 08-07-2020, 06:07 AM   #1313
84blaze
I've never liked how the radiators stick up past the factory shroud on these trucks. Since I'm on a S10 chassis the front frame horns and steering box rerally limit the depth of my radiator and made my Champion 4 core stick up way too much. I've since sold it since it wasnt working for me. I would like to find a rad that can fit within my dimensions and sit below this little sheet metal shroud I have.
Untitled by Spencer Wiedeman, on Flickr
Old 08-07-2020, 08:01 AM   #1314
youngrodder
Thanks Jim
On my 48 I used a G-body front clip which is petty much the same as a S-10. I lost 4" in radiator height because of the steering box. I used a Champion 4 core from a mid 60's mustang. it will still stick up some otherwise your radiator will be so small it wont offer adequate cooling.
The hose outlets even lined up for my LT1 (which I think are the same as an LS). Since you are running a shorter radiator you will need a good "sucker" electric fan (see my recommendation in my previous post) and build a shroud at the bottom of your core support to direct air up into your radiator. Before I did that my 48 always ran hotter than I would have liked.
Marc
Old 08-08-2020, 08:38 AM   #1315
reaper71
reaper71's Avatar
Looking great Marc.
I saw your post on "bickle" about your door seals from steele.
Have you looked at Soffseal? really nice products
Mark
reaper71 is offline   Reply With Quote
Old 08-08-2020, 11:10 AM   #1316
youngrodder
Originally Posted by reaper71 View Post
Looking great Marc.
Mark
Thanks Mark...I'm good on door seals. I used universal ones. I did the same on my 48 and they worked great. I need to get front and rear door window seals. ordered. I'm having all of my glass cut locally and it should be done in a week or so....thanks for the suggestion.
Marc
Old 08-10-2020, 09:35 AM   #1317
youngrodder
Ok, so I hit a major milestone this weekend. I asked a few buddies over to help drop the body back on. A few areas I was worried about as far as clearances go was the following: The coil clearance to the firewall. The shifter clearance coming thru the floor. Everything turned out better than expected. The only exception was the floor by the tranny. I had to cut more of the floor than I wanted/intended. The thing that changed between mock ups was the drive line angle and the height of the tranny mount. I will just come up with a trans tunnel..
Overall I was stoked with the outcome. Keep in mind that these rims are 20's. I plan to run 22's.
Considering that I painted the body panels separate from each other I was pleased how they look next to each other.
Here are a bunch of pics.
Old 08-10-2020, 09:37 AM   #1318
8man
That is looking great.
8man-aka Robert
Old 08-10-2020, 09:37 AM   #1319
youngrodder
More.....
Old 08-10-2020, 09:40 AM   #1320
youngrodder
More....
For comparison here is a before and after my paint distressing.
Old 08-10-2020, 10:04 AM   #1321
oldman3
oldman3's Avatar
Marc, looks great, nice job on the paint. Onward and upward...Jim
Old 08-10-2020, 10:24 AM   #1322
jbjburbs
jbjburbs's Avatar
dude.. so sick. Awesome work!
John J
Bodied 1994 Suburban on custom frame -
http://67-72chevytrucks.com/vboard/s...d.php?t=672297
Dad's 1948 Suburban -
http://67-72chevytrucks.com/vboard/s...d.php?t=563150
Bagged 1995 Suburban - SOLD
Bodied 1995 Tahoe -SOLD
jbjburbs is offline   Reply With Quote
Old 08-10-2020, 10:28 AM   #1323
youngrodder
Thanks for tagging along Jim...
Thanks man...
Old 08-10-2020, 11:56 AM   #1324
mongocanfly
now that's what we've been waiting/wanting to see..!!!!...looks great Marc..!!!...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-10-2020, 12:57 PM   #1325
youngrodder
Happy to oblige
Marc
