![]() Join Date: Jul 2015
Seat install - How do these springs go?
Not sure where that small spring goes? Across the long spring? Or across the connecting rod?
1963 C20, small window, long bed 292, 4-speed |
![]() Join Date: Feb 2011
Re: Seat install - How do these springs go?
MusicMan70 1961 GMC Suburban |
if you're referring to either one of these, those are for jack and tire tools..
![]() when I reinstalled my 65 seat, I installed both brackets and the connecting rod on the seat, then set it in the truck and bolted it down.. good luck!
I started out with nothing - and I still have most of it |
Ok, those are for securing the jack.
Moderator
![]() ![]() Join Date: Aug 2011
Correct.
Although there is a spring for the seat. You'll see a hole in the seat bracket you show that one end goes through. http://67-72chevytrucks.com/vboard/s...80&postcount=3
