![]() Join Date: Mar 2011
Re: Order of Operations - Cab repair/sandblast
I repaired most of my cab before blasting. I then blasted the entire cab ..and epoxy primed. The fenders, hood, and other parts were blasted and then patched and epoxy primed. I use crushed glass as my blasting media. On large panels, I stripped by hand. I still have the doors to do. I will cut out the rust on the bottoms and then before patching I will blast the insides of the doors, then epoxy prime the inside of the doors before patching the bottom.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
| Bookmarks |
| Tags |
| cab, rust repair, sandblast |
