Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-11-2020, 01:36 AM   #176
First c10
First c10's Avatar
Re: Creamsicle: My 70 K10 SWB is about to get sweeter
Truck looks great Dan I can’t wait to be able to say I am done other than a few things.
Enjoy that thing.....
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 08-12-2020, 07:45 PM   #177
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Originally Posted by 1972CST View Post
What an incredible build! You really have something to be proud of!
How did you like the Advance Adapter kit for the 4L60E to NP205?
I have heard mixed reviews.
Thank you for the compliment.
I had no issues with the Advance Adapter kit. What have you heard and what are the problems?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 08-12-2020, 07:46 PM   #178
derotoreut
derotoreut's Avatar
Thank you. You'll get there. In the meantime I'll keep watching your build. You're going a great job. Next up is my 71 swb. I need to get back on that build.
~ Dan
Old 08-12-2020, 08:42 PM   #179
IronCanine
I'm trying....
IronCanine's Avatar
Turned out really great Dan. Well done. Thanks for sharing.
IronCanine is offline   Reply With Quote
Old 08-12-2020, 09:10 PM   #180
derotoreut
derotoreut's Avatar
Thanks. That means a lot coming from a TOTM winner!
~ Dan
Old 08-13-2020, 09:52 AM   #181
1972CST
1972CST's Avatar
I have heard modifications were needed for the mount and inner drive sleeve that was not described in the instructions from AA.
1972CST is offline   Reply With Quote
Old 08-17-2020, 08:28 AM   #182
derotoreut
derotoreut's Avatar
I did not experience these problems. Plus any questions that I did have were answered by calling their technical support line.
~ Dan
Old 08-17-2020, 09:53 AM   #183
derotoreut
derotoreut's Avatar
Just another update from last week. On Aug-12th I installed the front speakers to complete my stereo installation.
Stereo:
  • Retrosound Long Beach with Motor-4 body
  • USB/Aux installed in original cigarette lighter location
  • External microphone for bluetooth phone operation
Front Speakers:
  • Kicker model CSC65
  • 6-1/2" Round, 300 watt max
  • Installed in front vent panel in Retrosound speaker mounts
Rear Speakers:
  • Kicker model CSC693
  • 6"X9", 450 watt max
  • Installed in rear cab corners speaker mounts from board member "Bigblock73"
Retrosound Long Beach with USB/Aux in cigarette lighter location
Front passenger side speaker
Front driver side speaker
~ Dan
Old 08-28-2020, 11:48 PM   #184
tim71
tim71's Avatar
I'm late to the party, just now stumbled across your build. Really enjoyed going thru your build postings. Congrats on a great build and a stunning truck.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 01-18-2021, 10:34 AM   #185
First c10
First c10's Avatar
Good morning Dan. I sent you a pm.
GO GO!!!
Old 02-18-2021, 09:58 AM   #186
derotoreut
derotoreut's Avatar
I've come to the conclusion that these trucks are like owning a home... You're never done working on them. My wife calls me the "Lowes Man", because Lowes' motto is "Never Stop Improving".
Well I decided to swap out my front Dana 44 drum axle with a newer mid 80's disc brake axle. I know that since I have the 1970 axle that I could've just rebuilt mine by swapping out components from the knuckles out, but I decided to do an axle swap. By the way, if anyone is interested in the 70 (one year only) drum axle let me know. I plan to sell it.
Time to remove this axle
Done. Axle is out.
~ Dan
Old 02-18-2021, 10:22 AM   #187
derotoreut
derotoreut's Avatar
Over the summer I found that I had some oil drips coming from my oil pan. I decided while I had the front axle out that I would correct the problem. Well I made two mistakes. The first one was using a fabricated oil pan. The Tilden pan is nice, but I think it contributed to my slow leaks. The second mistake I made was trying to change the pan gasket with the engine in place. I thought that maybe there would be enough clearance to be able to pull the oil pan out if I disconnected the motor mounts and jacked up the front of the engine. Well that didn't work. Maybe I should've tried to slide the crossmember forward to remove the pan instead. In the end I was able to get the old pan gasket out and a new one in. I know you're not supposed to use any sealant with the LS style oil pan gaskets, but I decided to put a thin film on the surface anyway. I just didn't trust the sealing surface of the fabricated pan. Unfortunately, I don't have much confidence that just replacing the gasket and re-torquing is going to solve the problem. I'll keep my fingers crossed and see what happens come spring.
Oil pan dropped down to remove old gasket
Front of engine jacked up for clearance.
Had to remove the pickup tube in place. What a mistake and PITA.
New gasket put in place.
New gasket installed and ready to button it up.
~ Dan
Old 02-18-2021, 10:41 AM   #188
57taskforce
All about them K’s
57taskforce's Avatar
Man that’s a shame it’s leaking, that sure is a nice looking pan. Nice work overall. That’s such a great looking truck, you’ve done a great job!
Tyler
Old 02-18-2021, 12:08 PM   #189
derotoreut
derotoreut's Avatar
It is a nice looking pan, but I think the fabricated pans just don't stack up to a cast/machined pan. It's reinforced around the bolting flange, but IMO the mating surface just isn't strong enough and flat enough like a machined surface pan. Thanks for the compliments.
~ Dan
Old 11-29-2021, 03:28 PM   #190
4thgencreamsicle
No idea how I missed this thread! Beautiful truck! We’re getting my own creamsicle going. My kids named ours the Creamsicle even though I had just always called it Grandpa Bill’s truck. It’s my great grandpa’s truck that my Dad put into his construction crew fleet for awhile so it’s got some pretty redneck/grandpa style fixes on it. We’re working through those kinks and hope to have it running & driving by the new year.
4thgencreamsicle is offline   Reply With Quote
Old 11-29-2021, 05:44 PM   #191
derotoreut
derotoreut's Avatar
Can't wait to see it. Do you have any pictures or build thread?
~ Dan
Old 11-29-2021, 08:07 PM   #192
4thgencreamsicle
I don’t have a build thread on here, but probably should since I’m on here all the time. I’ve been keeping track of our progress on my Instagram page ( chronic_creamsicle ).
Meanwhile here’s a picture. I’m keeping the “patina” since it’s always been a work truck until I got ahold of it. 😎 This pic was a few years ago, but apparently it’s one of the only full body shots I have. I need to wash her and get a better one.
Old 01-27-2022, 02:56 PM   #193
67pro-street
67pro-street's Avatar
Great looking truck, thanks for the detailed build and pictures! Question about your center console, did you buy a kit to refurbish it, or send it off to someone? I've got a center console that needs some TLC. Thanks!
67pro-street is offline   Reply With Quote
Old 02-07-2022, 10:44 AM   #194
scottmitchellrose
So here are some of the plans for my K10 SWB refresher:
  • Pull 307/SM465 and replace with 5.3L/4L60E combo (DONE)
  • Reseal and update NP205 transfer case (DONE)
  • Remove bench seat and replace with factory buckets and rebuilt console (DONE)
  • New Carpet (DONE)
  • Remove original fuel tank and replace with under-bed tank (DONE-Ricks Tank, made in Texas)
  • Update wiring (DONE-AAW Classic Update)
  • Vintage Air AC (DONE-Also added VA latest heater/AC control)
  • Ididit tilt steering column (DONE)
  • Dakota Digital gauges (DONE-Dakota Digital RTX with BIM-01-02 module)
  • Updated stereo (DONE-RetroSound stereo with Kicker front & rear speakers)
  • LS aluminum radiator (DONE)
  • Headers and exhaust (DONE-Speed Engineering Headers and polished SS exhaust)
  • New steering gear (DONE-Readhead steering gear)
Additional items not originally planned:
  • Firewall and cab floor insulation kit (DONE-Quiet Ride Solutions)
  • Custom bed floor with fuel filler (DONE-Smokey Road Rod Shop floor with 2" filler by Boyd)
  • Skyjacker drop pitman arm and drag link (DONE)
  • New Dana 44 pinion seal and cover (DONE)
  • New Power Steering Pump (DONE-Part#15909834)
  • Dapper OE7 LED Headlights (DONE)
  • Custom made core support and engine covers (DONE-Still need prime & paint)
It's quite the laundry list. We'll see how it goes.
I love the color/ name. any videos on how to replace the steering gear?
scottmitchellrose is offline   Reply With Quote
Old 02-07-2022, 10:47 AM   #195
scottmitchellrose
Attachment 2082763
Attachment 2082764
Attachment 2082765
Attachment 2082766
Attachment 2082767
I've heard the camaro pans work great with this swap.
