#26 |
Re: Battery not charging - tell me what I'm missing
Vettevet has the fuses circled in this thread. http://67-72chevytrucks.com/vboard/s...se#post6219269
Alternator voltage is dependent on several things. Battery state of charge, temperature, and engine rpm effect charge voltage. The small 37 Amp, EX reg Alternator can put out about 20 Amps at idle rpm. The SI alternators can only put out a maximum of 25 Amps at idle and again, that is only if the battery needs it. Full fielding an alternator is a viable test. It should only be done for a second. The voltage will shoot up to 16-18 volts and the load will drag the engine rpm down. That's all you need to know. You should use 12 volts from the battery or from Regulator terminal #3. The idea is to eliminate any possible problem from the Regulator and terminal #4 does not do that. The externally regulated alternator has one side of the field always grounded. The regulator controls the voltage on the other side of the field winding. The SI alternator has one side of the field winding always connected to 12 Volts. The regulator controls the ground side of the winding. Grounding that side, bypasses the regulator to test the Alt only.
'67 GMC 2500, 292, 4spd, AC |
#27 |
Okay know this is an older thread...jumped the truck, battery 13.9 and alternator reads 14.6 and the alternator is already one wire already. The voltage regulator has been removed by PO with some type of jumper box I’ve never seen. As soon as I turn truck off dies immediately and won’t even crank...I’m going ****en nuts here guys, please help!!!
Posted via Mobile Device |
#28 | |
#29 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
You should delete these two posts and repost in the electrical forum (http://67-72chevytrucks.com/vboard/f...splay.php?f=64) very few people will read your posts on a 7 year old thread.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
