Old 08-10-2020, 12:38 PM   #1376
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Switched out the fan clutch and shroud. I expected the “foreign made” shroud to be off some and sure enough it was. The two sides had about a 3/4” bow in them. I laid a straight edge up to it and snapped these pics. I trimmed it to fit and it’s hardly noticeable now. But REALLY?
Boog - You make me even more happy my original shroud is in good shape.
On these two benches is basically the entire front end minus the brake hardware. 2-1/2" drop spindles, new stock height springs, etc. Got the tie rod ends and adjusting sleeves mocked up loosely on the drag link, new rubber bumpers in the upper A arms, new ball joints in the lower A arms. Trying to wrestle the new rubber bumpers in the lower A arms now. New cross shafts, bushings, idler arms, and lower A arm u bolts.
All I really need is some time right now. Well, and some cool weather.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-10-2020, 12:53 PM   #1377
Boog
laying low
Boog's Avatar
Didn't I see a window air conditioner in your shop when I was there? I have one yet to install however. Maybe next year..
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-10-2020, 04:44 PM   #1378
67C10Step
67C10Step's Avatar
Man, I wish. Just some fans out in my shop for now. Hot hot when it's 90+ temp and the humidity is up.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-10-2020, 10:07 PM   #1379
Boog
laying low
Boog's Avatar
I put in a full day here. Yard work this am and truck work all afternoon. It got up to 98 or so outside and pretty much the same in the shop. I use a fan on a pedestal. Since I saw you I've been moving the engine/tranny to the rear set of frame holes which freed up room between the water pump and radiator since I have the 70's to 80's long water pump setup. I installed a new fan clutch and shroud. Today I redid the exhaust system. I never cared for how the pipes hung down so low and also did not care for the magna blow muffs. I yanked all that off and grabbed the sawzall, grinder, mig welder and went to town on it today. Yeah, it was super hot but I was enjoying what I was getting done so it was a good day. Now tomorrow I don't expect to even open the shop door.
Boog
primer is finer
Old 08-10-2020, 11:08 PM   #1380
WorkinLonghorn
WorkinLonghorn's Avatar
Eight solid non-stop hours removing hood, all fenders and core support. Installed good core-support and two fenders and re-installed the crappy hood that I have. Still need to install the inners and the grill, than I'm back on the road! Got a chance to use my new Makita cordless impact wrench. Pure joy it was. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-11-2020, 10:25 PM   #1381
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sold it.
Blasphemy
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-12-2020, 02:08 PM   #1382
72c20customcamper
72c20customcamper's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
Blasphemy
Looking for 67 to 72 burban to replace it. I'm a gluton for punishment
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-13-2020, 12:18 AM   #1383
BC10
BC10's Avatar
Put the bed together, and onto the frame! Finally!!!
BC10 is offline   Reply With Quote
Old 08-13-2020, 10:12 PM   #1384
71CHEVYSHORTBED402
Measuring for a driveshaft, I thought I better put some weight on the frame just in case, so I loaded a dozen 50 lb. bags in the sweltering heat of Noon & no breeze, half-way through thinking "I'm too old for this *&%".
Good thing I added the weight...........Just kidding, I measured before and after, the weight didn't change a thing At least I had an excuse to torque the leaf springs.
Tony
Old 08-15-2020, 10:27 PM   #1385
ThreeQuarter
ThreeQuarter's Avatar
Drove it for the first time in 7 years...75 feet to the end of the driveway! Pic below is at the end of my journey. The transmission goes and the brakes stop, but I gotta get the engine tuned up before I go any farther.
Oh, and I washed it for the first time in 5 years.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 08-16-2020, 12:01 AM   #1386
Sheepdip
Sheepdip's Avatar
Can't believe you don't drive that nice looking rig!
Sheepdip is online now   Reply With Quote
Old 08-16-2020, 12:10 AM   #1387
BC10
BC10's Avatar
Time flies, that's for sure. I am loving that truck!
Old 08-16-2020, 12:18 AM   #1388
Sheepdip
Sheepdip's Avatar
Got my new "Gates" V-Belt installed on my A/C Compressor, I've had it for about a month sitting on the bench in the barn.
My O'Rielly's Duralast rubber band just kept on a stretch'n and finally in slow traffic with higher pressures would slip and squeal, not to mention it was too narrow and bottomed out on the pulleys.
So as hot and humid as it's been I finally broke down and swapped it in this morning.....problem solved!
Love my A/C, even with the fan speed on low it will cool the cab down really nice in
100+ deg. heat.
Old 08-16-2020, 01:45 AM   #1389
68bowtie
68bowtie's Avatar
Boy, I’m feeling 503 green with envy. That is a thing of beauty! Is there a thread with more history and pictures somewhere?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 08-16-2020, 02:10 AM   #1390
leddzepp
Moderator
leddzepp's Avatar
I Drove the 68 today to 3 different parts stores on the hottest day of the year to buy AC parts to restore/fix the AC in my 2001 Yukon XL, while enjoying ice cold air in the 68 that I restored 3 years ago
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-16-2020, 07:06 AM   #1391
ThreeQuarter
Hey, thanks, it’s nice to hear compliments after years of work to get her to this point. I never made a build thread but here’s a thread from the day I picked it up, it includes a little history. The firewall was Swiss cheese and as everyone here knows, one thing led to another which led to a full resto. Driving it on a weekly basis is the goal, but I have to get the engine right first.
Ben
Old 08-16-2020, 07:57 AM   #1392
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-17-2020, 11:26 AM   #1393
67C10Step
67C10Step's Avatar
Spent a few hours yesterday wire wheeling and sand blasting every part of the frame I could get to with the cab still on and engine still in. I'll do the rest at a later date when there is access. No need to get all crazy on a drive quality, rusty old truck. It's already going to look better underneath than on top for a while.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-17-2020, 11:48 AM   #1394
katwalk
Finished up the new suspension.
katwalk is offline   Reply With Quote
Old 08-17-2020, 11:52 AM   #1395
Ol Blue K20
Nice!!!!
Dale
Old 08-17-2020, 04:04 PM   #1396
Boog
laying low
Boog's Avatar
I've been hearing about using a few different items to soak metal parts in to remove rust. Over the weekend I soaked a couple pieces of metal in a thin vinegar/water mix and let it sit over night. Since I did not have a pan large enough to completely submerge one part I had to do it one end at a time which didn't work out too well since the exposed end rusted right up and I had to do it all over again to clean that up. The 2nd part I had already wire wheeled heavily and didn't make much headway cleaning it and after over night in the mix it wasn't much better so since it was a thicker piece of metal I used the grinder on it and removed most of the deep rust then returned that part to the mix for a while then it came out acceptable. I washed them both in a baking soda/water mix to neutralize the vinegar's acid. I blow dried them right away and epoxy primed them. For small parts this is easy and cheap enough to do.
Boog
primer is finer
Old 08-17-2020, 04:34 PM   #1397
ohboy321
ohboy321's Avatar
Media blasted and painted a power steering pulley. I have 2 different PS pulleys painted and ready to install...hopefully one of them is correct.
I also put some casters on my fancy painting rack....that way I can spray away from the garage/vehicles and roll it inside to finish drying at night.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 08-17-2020, 09:53 PM   #1398
SoCoC10
SoCoC10's Avatar
Installed the gas filler neck gasket. Assembled and installed the fender dust shields and cleaned polished and painted some emblems.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 08-18-2020, 07:48 AM   #1399
70cst
70cst's Avatar
I purchased this ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-18-2020, 10:20 AM   #1400
OregonNed
OregonNed's Avatar
Oil change, and ready to drive it to work tomorrow
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
