Old 06-29-2004, 11:47 PM   #1
bwright
88 S10 V8 (tn)
88 S10 V8 - $1,900 obo/trade
Here's the specs on the truck:
- 1988 S10 SWB std Cab, Red
- '74 350 2 bolt main (std bore (checked by machinist, no overbore was needed), new rings/bearings/etc, 282 cam, alum intake, new 1 wire alt., some chrome accessories), heads were in good shape (put new seals in), new battery, new headers, Carter AFB carb, JTR motor mounts, rebuilt HEI w/curve kit, new radiator, new flex fan, engine has been broken in...sounds great
- TH350, worked good in the truck it was in (replaced seals & filter, added chrome pan w/ drain plug), driveshaft cut and balanced w/ new ujoints, new B&M Zgate shifter, 2500 stall TCI converter
- Lowered w/ 2" blocks in the rear and new 3" DJM springs in the front, new shocks, manual brakes and steering, new 15x8.5/15x4 Centerline whls, new tires, traction bars (not installed)
- Body is in decent shape...I replaced the cab corner. Most of the frame has been sandblasted and painted. There's a couple dents, nothing major. Needs paint. New late model grill. Extra hood. No tailgate. Crack in windshield.
- Interior is completely stripped except for the stock bench seat & door panels. I have some decent Blazer buckets to go with it. Passenger side of firewall cut out for header/trans clearance, almost finished closing it in w/ sheet metal. New small 3 guage panel & large tach.
Very little work to be ready to race. Pics available. Located in Dickson, TN
bwright is offline   Reply With Quote
Old 06-30-2004, 07:47 AM   #2
Blue Beard
Blue Beard's Avatar
Post some pics on the board, might help you sell her...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
