Active Member
![]() Join Date: Aug 2012
Vintage Cruise Control on the '64
I'm helping a friend on his '64 C10. It's a project we have been working on for a while.
I have a lot of experience with the GM cruise control systems used from '67 up through the early '80s, so we decided to install one on the '64. It's just in the mock up stage but I thought I'd show a picture of it as it is now. Still have to mount switches under the dash, add grommet at firewall and plumb vacuum feed to rear of carb. I used to add this system to other GM vehicles and still have a large inventory of components. Hope someone can rotate the image. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Vintage Cruise Control on the '64
Here you go.
![]() ![]() ![]() Join Date: Jan 2018
That's something that I want to do on my truck at some point. Is it pretty easy?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Active Member
The installation is pretty easy. The biggest problem I had was routing the speedo cable. I notched the upper support bracket for the brake pedal so the cable would have a better angle attaching to the speedometer cluster.
Do a search for Buick cruise control. There is a really good thread that explains the system and how to troubleshoot. When you get ready, let me know. I'll help you and tell you what vehicles have the necessary components. |
That's good to hear, thanks!
Many years ago I installed a GM (Pontiac) cruise control on my 79 CJ7. Still working today. I still have a few parts left snd hope to put one on my 65 C10 some day.
Moderator
What year and model Pontiac cruise control?
Hi Rocknrod, I am guessing the mid 70's for the year. This unit was a factory option on most GM models. The one you have pictured is I believe from a later model.
Hairball |
| Bookmarks |
