Junior Member
![]() Join Date: Dec 2018
'61 temperature gauge
Just finishing wife's '61 fleetside short box, 283 cu. in. powerglyde. During a shake down cruise, the original temperature gauge would go almost to the hot side.
Using a digital temperature gun, the thermostat housing read 180 degrees. Because the speedometer starting going crazy, I decided to replace it and the temp and fuel gauge as long as I had to take the cluster back out. Sourced and installed Counterpart gauges and speedometer. Before reinstalling the cluster back in the dash, I tested the lights etc. Letting the truck run outside in 85+ degree heat with the air conditioning on, the needle on the temp gauge would only come up to the cold line. Checked the temperature again at the thermostat housing, it reads 187 degrees. I have a new wiring harness, 180 degree thermostat, 01513321 temp sender and no sealant on the sender into the intake. The gauge is wired correctly (12v to ignition and other side to the sender as marked on the back of the gauge). Am I missing something or just have a bad (new) temperature gauge? |
Junior Member
Re: '61 temperature gauge
And I grounded the cluster to the dash for testing.
Active Member
![]() Join Date: Jan 2017
Klas, I am anxiously waiting for a response to your question as I have the exact same situation on my '60 I just finished restoring. I know it doesn't matter, but I even have a 283 and power glide.
Submariner616 1965 Chevrolet K20 350 4 speed manual |
A friend of mine uses the stock temp guage and tells me that normal operating temperature is mid way between C and H.
Moderator
![]() ![]() Join Date: Aug 2011
Read post #3 and #4 here - http://67-72chevytrucks.com/vboard/s...d.php?t=525139
Junior Member
Thanks for the responses so far.
I'm sure I have the correct sender and used no sealant installing it. Talked with the Truck Shop where I bought the gauge. They suggested checking an adequate ground at the gauge to the cluster, and the cluster to the dash. Also, check that the two posts on the gauge are sufficiently isolated from the housing. They said they've had good luck with these gauges and want to know what I find. Further offered to replace and test my gauge for proper operation. Will check today and update. |
#7 | |
Active Member
Active Member
I received the temperature sensor from Lectric and installed it. No luck, the gauge still does not work. The search for a fix continues.
Junior Member
Sorry for the delay in responding. Don't lose faith! I'm running some tests on temperature senders and will report what I've found. To this point I'm finding that not all temperature senders are created equal.
Not all sensors are created equal. Little variances in materials can make the readings different. The rocknrod gave a link to resistance chart for our senders. if you have a multimeter you can test the resistane that it is putting out. Test it cold. Put your thermometer in the cold water, once you know the temperature of the water, put one lead on the threads the other lead where the wire connects to. It will give you an ohm reading, compare it to that chart. Do the same test with hot water(dont burn yourself), again compare the reading with the chart. If the sensor reads close enough, thats the one you want to use. Plumber by trade, i can tell you that the threads on those sensors are tapered, meaning that as long as the threads are correctly made, you wont need a sealent to make it seal. Tighten hard(better seal, better ground connection), if it leaks tighten some more.
Junior Member
I tried to run some tests of different senders by checking the ohms at different temperatures. That didn't work out like I anticipated. So, I changed out different senders in the truck and ran the truck to operating temperature.
I'm using an aftermarket gauge; no sealant on the sender; pink wire on gauge to 12 volt; green wire on gauge to sender and the cluster installed in the truck. This is what I found: Sender Position on temp gauge Lectric Limited #01513321 1/4 way off C Truck Shop #60-12802 (Lectric Limited #01513321) 1/4 way off C NAPA #2 (bought a year ago) Echlin TS6469 3/8 way off C NAPA #1 (bought recently) Echlin TS6469 1/2 way off C Truck Shop (Import) 60-12802-1 1/2 way off C ORielly Standard #T56 3/4 way off C I decided that the senders will give different results even if they're the same part number. And probably the original gauge will operate differently than the reproduction. In my case I'm going to run the NAPA #1 or the Truck Shop Import as the needle on the gauge is in the middle and the temperature at the outlet housing reads at 180 degrees. Hopefully this is helpful. |
Moderator
Thanks, this is all good information. What does it mean by 1/4 way off?
Junior Member
The numbers listed are how far the gauge needle has traveled above the cold (C). So 1/4 is 1/4 way past the cold (C) toward the hot (H).
That's really interesting. It's really something to bear in mind. If you had a Truck Shop or Lectric Limited sender it could be possibe to overheat your motor at 1/2 way off while all the while thinking everything is fine. Conversely, the O'Reilly one would make you believe you're running hot. I'm surprised your thread hasn't received more responses as this is kind of a big deal. Thanks for doing the research.
#15 |
Junior Member
Tchevs, your information is spot on. And AcampoDave, thank you for your response.
I've restored several vehicles to "as delivered from the factory" for customers. And those vehicles were expected to drive as they were new. Unfortunately over the years, original parts are harder to find and we have to use aftermarket parts. As Tchevs pointed out, not all temp senders are created equal. Sometimes the conventional wisdom doesn't hold true. I knew the engine wasn't running hot and needed the cheapo Harbor Freight infared temp gauge to prove it. This forum is a great resource and we all appreciate the information. |
#16 | |
Moderator
http://67-72chevytrucks.com/vboard/a...1&d=1303785949
| Bookmarks |
