Old 08-11-2020, 01:06 PM   #51
69Tom
69Tom's Avatar
Re: Restoring OEM Seatbelts
Originally Posted by Factory Guy View Post
In the older trucks (my case a 1973) is there an upper mounting point for a 3 point seat belt? I would like to get 3 point seat belts installed in my truck.
My 74 has an upper mounting point. You'll have to cut a hole in the plastic trim.
69Tom is offline   Reply With Quote
Old 08-11-2020, 05:02 PM   #52
TKCR
TKCR's Avatar
Originally Posted by rodstored-72 View Post
TKCLR, your restoring abilities - seatbelts & seats are really amazing!! I am sooo tempted to send you my belts!! I still need to get my sunvisors & just maybe I might send a shipment your way.... hopefully!
Thank you and I would be happy to do your seatbelts. You can also message me thru my FB Page for my seats. The link is on my Signature.
Old 08-11-2020, 05:09 PM   #53
TKCR
TKCR's Avatar
But where would that black retractor box go? I have to admit I have never seen this style of seatbelt installed in a truck. I’m more familiar with the 78/79-87 style of seatbelt.
Old 08-11-2020, 08:54 PM   #54
K25alive
The black retractor hooks then bolts to the rear pillar. Here is a pic of my 1977 C10 retractor. The bolt is a star head bolt.
K25alive is offline   Reply With Quote
Old 08-11-2020, 09:23 PM   #55
TKCR
TKCR's Avatar
Thanks for the pics, that helps a lot
Old 08-17-2020, 07:31 PM   #56
TKCR
TKCR's Avatar
Just restored a set of 87 Saddle Tan seatbelts for someone. I don’t usually do this, but he wanted his retractor casings done in Dark Saddle. But they will look good in his truck.
First pic is the Before, they were FILTHY! It took a couple of good hot baths, along with several good scrubbings.
2nd pic, is his truck the belts will be going in.
The rest are AFTER!
Old 08-18-2020, 11:34 PM   #57
StorminNorman
Nice work. Do you install new webbing ?
81 short step.
StorminNorman is offline   Reply With Quote
Old 08-19-2020, 07:34 AM   #58
TKCR
TKCR's Avatar
No. Through cleaning. Dye if needed, for the fading.
Old 09-10-2020, 07:50 AM   #59
TKCR
TKCR's Avatar
Got another set done for someone. These are Charcoal.
Old 09-16-2020, 08:03 PM   #60
TKCR
TKCR's Avatar
Restored a set of 1987 Burgundy belts for someone. These were the typical dirty and faded belts. The metal buckles had a bit more rust on them, causing some pitting. I did replace the buckle cover since there was pitting of the metal. Also sandblasted the mounting tabs of the rust.
I will also be the Blue set for the same customer. So check out the Before and After pics.
Old 09-16-2020, 08:05 PM   #61
TKCR
TKCR's Avatar
After pics!
Old 09-17-2020, 06:50 PM   #62
TKCR
TKCR's Avatar
Found a repair method for the badly rusted buckles. I was able to get the rust off, but the metal is still pitted. So I removed the cover, and at this time I touched up the inner emblem piece. Then installed a new metal cover.
Old 09-18-2020, 02:45 PM   #63
Jeepwm69
Man those belts look fantastic.
Jeepwm69 is offline   Reply With Quote
Old 09-18-2020, 05:57 PM   #64
TKCR
TKCR's Avatar
Well thank you!
Old 09-18-2020, 06:18 PM   #65
TKCR
TKCR's Avatar
So I’ve been working on the Blue 87 belts. Didn’t get a really good before pic of them, but what I do have. I just get started on them and the remember, crap I didn’t get any good before pics! So here’s what I have. On the buckles, I changed out the cover and inner GM emblem button. On of those wasn’t even working. Of course i didn’t get a picture of that, but when I took the buckle apart, it had a wad of chewed gum in a wrapper. It was jammed inside the buckle! No wonder I didn’t work.
Pics 1-3 are before
4 & 5 are after
Old 10-02-2020, 09:16 PM   #66
TKCR
TKCR's Avatar
These here, I restored for a good friend of mine. She is doing the interior of her 1966 Chevy Truck. At the present time, she has aftermarket belts, which are too long, and there’s no retractor. So I restored a set of 73-75 belts. The buckle covers were cracked, so we got some new replacement Buckle Cover kits. They came with new buttons and emblems. I sent her home with one of the cracked buckle covers, that I dyed real quick with Dark Saddle, to check the color match. So the retractor casings & buckles are done in Dark Saddle. The webbings are Camel Tan, so those we’re throughly cleaned and dyed with the original color.
Old 10-02-2020, 09:18 PM   #67
TKCR
TKCR's Avatar
Here are the AFTER pics
Old 10-06-2020, 07:17 PM   #68
TKCR
TKCR's Avatar
Here is a set of Lap Belts only. These were common on the 73-75/76. These are the 77-79 Blue. The seats belts were pretty dirty. I bet I soaked them 6 times in hot soapy water, until the water was no longer looking like chocolate milk, that’s how bad they were. Took everything apart and throughly cleaned everything and prepped for dye. So here they are!
First set of pics are BEFORE
Old 10-06-2020, 07:20 PM   #69
TKCR
TKCR's Avatar
And here is the AFTER
Old 10-06-2020, 08:09 PM   #70
44th Miss Inf
Nice work, as usual Tina. Those look great
44th Miss Inf is offline   Reply With Quote
Old 10-06-2020, 08:34 PM   #71
TKCR
TKCR's Avatar
Thank you! These took a lot of work!
Old 10-21-2020, 10:19 AM   #72
TKCR
TKCR's Avatar
Working on another set of Belts for someone, 1987 Blue. This is something that I do when restoring seatbelts. I take apart the buckle, to clean & lube. This would also be the time to replace the cover, if it is pitted with rust. But occasionally I find foreign objects inside the buckles, that keep them from functioning properly.
Pics are what the buckles looked like Before.
2nd pic, is of the paper stuffed in the buckle.
3rd pic, After cleaning and reassembling.
Old 10-23-2020, 07:31 PM   #73
TKCR
TKCR's Avatar
The belts in the above post are completed. Here are the pics.
Old 10-24-2020, 07:31 AM   #74
4u2nv
Outstanding workwomenship
4u2nv is offline   Reply With Quote
Old 10-29-2020, 10:28 AM   #75
kitsbeach
kitsbeach's Avatar
Very nice. I have a set of aftermarket lap belts in my '67, but they are not the same.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is online now   Reply With Quote
