Do these trucks have locking steering columns?
I’m picking up a 75 soon that the previous owner lost the key for and am making plans to drag it out of where it’s been sitting for the last 15 years - did the steering columns lock in 75? Coming over from the 67-72 side of the forum and these trucks I’m less familiar with - thanks I’m advance!
Re: Do these trucks have locking steering columns?
By 87, they were definitely locking. I don't know when they started, though.
I'd like to disable mine somehow. I like the ability to kill the ignition while rolling to a stop. Unfortunately, I've gotten in the habit of killing the ignition and pressing the lock button(manual trans) in single smooth move. The abrupt loss of steering has caused a few panic stops!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
My 75 C10 column locks.
It is a bit of a PITA, but you can pull the steering wheel and remove guts until you get to the key tumbler. Assuming you are wanting to drive it at some point, it is something you will have to do anyway to replace the existing tumbler with a new one with keys. Once the tumbler is out, you simply turn the ignition linkage with a large flat blade screwdriver. Thieves simply yank the tumbler out of the column and then use the screwdriver. This approach breaks the column but the vehicle can be started and driven. |
Locking column started in 1973, when they moved the key to the column from the dash
![]() My understanding is that you can pull the wheel and remove the locking ring without breaking anything (but there is a special tool to get the spring off).
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
![]() Join Date: Feb 2000
The column in my '74 does not lock and does not have any interlock being a 4-speed truck. The owners manual states that the locking feature is only for automatic transmission equipped trucks.
The service manual mentions that the key should turn to lock only when the transmission is placed in park or in reverse (for manual transmissions). I assume this is for column shift 3-speed manuals since the 4-speed doesn't interact with the steering column at all.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
My 76 does not lock but I always assumed that was because somebody broke or took out the locking ring, as it does not have the factory steering wheel.
Back when I worked at the Chevy shop, some lady brought it a Vega for service and left with the keys, and the car blocking the service aisle. It was a stick shift so we could roll it but the steering wheel was locked. The wheels were turned slightly so it kept wanting to run into the wall, but a bunch of guys just grabbed the front end and scooted it over several times until we could get it into a spot out of the way ![]() So floor stick shift doesn't mean the steering wheel doesn't lock.
I checked another owners manual- a 1979 truck. The lock position prevents normal use of steering wheel and shift controls. The key cannot be returned to lock and removed unless the shift lever is in park on or reverse (on 3-speed manual trans). If it is a 4-speed equipped the lock position prevents normal use of the steering wheel. The key cannot be returned to lock without pressing down on the key release lever.
Also, there is no mention of the steering column locking in the GM service manuals for floor-shift transmissions until '79. The anti-theft locking feature is also mentioned in the '79 Vehicle Info Kit but not in years before that. The only thing the lock feature does on my '74 is prevent you from taking the key out in any other tumbler position. Not sure when the key release lever was implemented but that would narrow down the floor shift difference with the column locking. Maybe someone with a couple columns laying around could test if the floor shift-prior to 79- will lock. Cars were typically different than trucks and had features (comfort/safety) before trucks did but since in '79 they mentioned it in the owners manual it had caught on by then. Even vans were different animals and exceptions noted in the service manuals.
![]() Join Date: Jun 2019
My 1973 has a locking steering column, still works great no issues.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
The easy way to tell if it has locking steering columns look under the hood if the trans shift linkage has the rod that comes up to the column by the bearing then yes. most 75 up A/T had the locking column. I forget now but the early 73-74 it was a option have or not.
on the stand on the tree this was option most early did not have it. But I be leave 78-79 a lot more started to have the locking columns. All you have to do is pull out pins out of the lock out rod for the column. Then take out the clips to the shifter rod off . Then you can shift the trans under the truck to what gear( make sure you take the Batt off line pull the main coil wire off.). Then to the column take out the horn remove down to the key ( there is too style column keys take apart for your year remove the key like you had a bad lock or broken lock then the column can be able to steer it. ( can be replaced then or after you get the truck moved or pulled on a trailer). Attion: Make sure your not on a hill. You have it chained to a truck tree & blocks it and help. Three four people works good, so you do not get rolled over by truck. Make sure You plain your game and have all your Safty stuff you may need. Think about it use common sense and ever thing with go good.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
