Old 08-21-2020, 12:17 PM   #1401
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Finished up welding the firewall and cowl gutter. Little more grinding then it's ready for filler . Hope to have it painted this weekend
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-21-2020, 06:04 PM   #1402
weq92f
weq92f's Avatar
Put in the last little bit of 134a to get to the prescribed 1.8 lbs total for my VA system...Now she blows just a hair over 38 degrees vent temp @ 92 ambient!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-21-2020, 06:37 PM   #1403
SoCoC10
SoCoC10's Avatar
Made some progress on my 71 Cheyenne SWB. Shortened the parking brake cable and got it working again. Pulled the wiring front to back and the taillight harness. Built both doors. Installed 1/4 windows and side windows after removing the old window tint with oven cleaner and black trash bag trick. Installed the required longer regulators and longer latch controls for the 72 doors. Hung the fenders, hood hinges and hood.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 08-21-2020, 07:51 PM   #1404
efc1878
My first ever post on here and fitting that it is about something I did to my truck today. Tinted all the way round.
efc1878 is offline   Reply With Quote
Old 08-21-2020, 08:11 PM   #1405
72Cheyenne454
72Cheyenne454's Avatar
Nice truck and the tint looks great!
72Cheyenne454 is offline   Reply With Quote
Old 08-21-2020, 08:25 PM   #1406
72c20customcamper
Welcome to the dark side soon you will have 10 trucks .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-21-2020, 08:33 PM   #1407
Lee H
Lee H's Avatar
Welcome to the forum.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-21-2020, 08:39 PM   #1408
Boog
laying low
Boog's Avatar
Welcome aboard. Niiiice truck.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-21-2020, 10:04 PM   #1409
67C10Step
67C10Step's Avatar
Put all my parking brake cables back in and realized I’m short one of the pigtail looking cable guides. There was only one when I took it apart and when putting it back together it didn’t look right so I checked on here. Sure enough, another part I’ve now gotta find.
Started putting the front end back together and got the upper and lower a arms installed on the passenger side. When I tried to put the new MOOG spring in it appears something isn’t right. Looks like when the top seats properly the bottom is clocked about 1” past its seating point. Arrrggghhh! I stopped at that point.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-23-2020, 02:17 PM   #1410
ohboy321
ohboy321's Avatar
Put a coat of primer on the steering wheel I'm restoring. I started the project back in March and little by little its getting closer to paint. Primer reveals I have a little more work to do, but it is a huge difference from what I started with.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 08-24-2020, 08:57 AM   #1411
72c20customcamper
Finishing up the cowl firewall area. Just a little block sanding left . Going to paint the dash since the windshield is out. Looking at the dash it appears to be flat or satin saddle fawn on top would that be correct for this year truck ? Vents are a brownish also . Hopefully paint it this week then steam clean and detail the motor and frame. Finally will be able to test fit the clip
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-24-2020, 09:58 AM   #1412
OregonNed
OregonNed's Avatar
Got the Dynomax mufflers in - very pleased with the improvement
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-24-2020, 12:43 PM   #1413
67C10Step
67C10Step's Avatar
Making progress on the front end. Discussed this with Boog over the weekend. This side fought me the whole way. Bushings were a bear, spring didn't want to clock right, etc. But, I pushed ahead and got it all together, torqued, and greased. Got the upper A arm on the driver's side and working on the bushings/cross shaft in the lower now.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-27-2020, 09:43 AM   #1414
Davidf
This past weekend, finished up the assembly of the repainted fenders and new grille. The right fender is a reproduction and definately does not fit as well as the original fender. This project is a refurbishment where the truck will be used as a truck, so not spending so much time making this perfect.
But, started on the hood. First thing was to put the crown back into the center spine...that worked out well. Next was removing old paint. The front corners had cracking paint so investigation turned up lots of body filler over previous damage. Further inspection indicated the curvature of the front corner was wrong. Template is of the other side. Now, I have to improve this rather than 3/8" of body filler. So, time to cut out some metal and weld in new pieces to get closer to the proper shape before reasonable amount of body filler. Ugh!
Davidf is offline   Reply With Quote
Old 08-27-2020, 09:55 AM   #1415
C10Nick
Got my new wheel and tire set up all dialed in.
Kept the 15" steel wheels, added some center caps from an early 2000's fullsize and topped off with a set of 2" beauty rings.
C10Nick is offline   Reply With Quote
Old 08-27-2020, 08:06 PM   #1416
tdangle
tdangle's Avatar
New tank. Lots of rust and crude in the old one.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-28-2020, 10:42 AM   #1417
OregonNed
OregonNed's Avatar
I have the work area ready for new exhaust gaskets (manifold and collector sides) to go with the new muffler additions. Ordered the Remflex brand, and will be doing this Saturday. Will post a few pics when done...
Old 08-28-2020, 12:04 PM   #1418
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Yes on the pics
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-28-2020, 06:30 PM   #1419
72c20customcamper
Got the SEM self leveling seam sealer and did the roof today hopefully epoxy prime the roof and firewall. Hopefully have it done by Sunday eve
but this is the best tool I ever bought for stripping metal
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-28-2020, 11:58 PM   #1420
BC10
BC10's Avatar
By Sunday but this is the best tool I ever bought for stripping metal
Wow, I wish I knew about this tool when I was stripping my truck. Looks great!
BC10 is offline   Reply With Quote
Old 08-29-2020, 09:46 AM   #1421
72c20customcamper
Works great still on the first stripping drum . Also have a 60 and 80 grit drums. This truck has been a pleasure to work on no hidden surprises. No rot around either the front or back windows. Found one small dent on the roof
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2020, 06:33 PM   #1422
basketcase
basketcase's Avatar
I found my floor. It was piled with parts when I got it and I never cleaned it out til now. I'm working on the wiring and needed under the dash. Solid floor with only surface rust where the rubber mat wore through.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 08-29-2020, 07:47 PM   #1423
OregonNed
OregonNed's Avatar
Started my exhaust gasket project today. Still waiting on the collector gaskets, but the manifold gaskets are installed. Pretty happy with the way they went in.
Here is what I started with when I took them off..
Old 08-29-2020, 07:48 PM   #1424
OregonNed
OregonNed's Avatar
Left side
Old 08-29-2020, 07:49 PM   #1425
OregonNed
OregonNed's Avatar
right side
