Old 08-21-2020, 11:38 PM   #1
vitamin_c95
Transmission question-hard to shift from park
Curious about my th350. Anyone had an instance where it was hard to shift.out of park? I thought it was just the incline of where I park (4 times now, twice in driveway). Yet, when I parked in the street (level) It still fought me coming out of park. Only out of park, rest of gear range shifts like butter. I am able to gently rock the truck and shift it out of park when ever it does get stuck, which is why I thought it was binding up in the park pawl. Its comparable to a newer car with the shift lock mechanism not letting you shift until you hit the brakr pedal. Is that something internal, or is it something else?
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 08-22-2020, 08:15 AM   #2
rockyrivermark
Re: Transmission question-hard to shift from park
Check the dedent mechanism to make sure it’s not binding there.
rockyrivermark is offline   Reply With Quote
Old 08-22-2020, 10:16 AM   #3
vitamin_c95
Appreciate the response. Will check that this morning
Old 08-23-2020, 12:09 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Spray some PB Blaster, Liquid Wrench, or something similar into the top of the steering column, where the shift lever goes in. Don't be afraid to stick the nozzle in above and below the lever and give it a good dousing. After you spray it pull the shift lever up toward you and push it back down toward the dash. It should move up and down a couple of inches. Do this 4 or 5 times. This will help free up any sticking in the shift lever tube. The reason the shift lever moves up and down is because it should be pulled back towards you to shift it into and out of the park position.
It wouldn't hurt to spray the bottom end too, where the shifter arm comes out.
LockDoc
Leon
Old 08-23-2020, 12:25 AM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Doesn't all that spray guck drip out somewhere inside the truck? Who wants that guck on their carpet? Or am I missing something?
~Steven
Simi Valley, CA
Old 08-23-2020, 03:30 AM   #6
mr48chev
mr48chev's Avatar
It shouldn't where Lockdoc showed to spray.
Are you pulling back slightly on the shifter. My 71 has been torn apart for a while but I think I had to pull back on the shift lever to get it out of park. Kind of like moving a floor shift to the side to get past the detent.
My ongoing truck projects:
Old 08-23-2020, 08:54 AM   #7
LockDoc
LockDoc's Avatar
If a guy is worried about that they could try a little squirt first...... and hold a rag under it. I guess you could also remove the column and do it on the work bench if you wanted to do it the hard way.
It's just a suggestion, and it works 90% of the time for the problem the OP has.
LockDoc
Leon
Old 08-23-2020, 10:47 AM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'll pass on pulling the column. Mine is hard to get in/out of Park in cold weather. Maybe this is what I need to do.
~Steven
Simi Valley, CA
Old 08-23-2020, 11:19 AM   #9
garyd1961
If you have a column shifter knock the pin out and remove the shifter. Grease the ball on the end of the shifter and reinstall making sure it goes in correctly.
When I first got my truck I had the same problem for two years. I oiled the linkage under the hood but it didn't help. One day I noticed the pin in my shifter handle was working out so I pulled it on out and removed the shifter handle.
I forget exactly how but I could tell the shifter was in wrong. I greased it and put it in correctly and haven't had a problem since. Shifts like brand new now.
garyd1961 is offline   Reply With Quote
Old 08-23-2020, 07:03 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yes, column shift. I've had my lever out due to the roll pin walking out, as well. Too bad I didn't think to grease it then! It's frying-eggs-on-the-sidewalk-hot outside right now, so that job will have to wait until tomorrow morning. Thanks for the pointer!
~Steven
Simi Valley, CA
Old 08-24-2020, 07:05 PM   #11
vitamin_c95
As for me, yes I am.pulling back.on the shifter. It just gets stuck like a shift interlock on the newer cars. I'm gonna line spray it in the next few minutes. Just got home from work it was was super miserable muggy today. Thank you all for the responses.
Old 08-24-2020, 09:31 PM   #12
vitamin_c95
I sprayed the detent/column area with pb blaster. It was shifting fine before I messed with it today, but it does seem like it's got a stronger "pull" than before. So give it a few days and mess with it and also park on the few spots it gave me problems before
Old 08-24-2020, 09:57 PM   #13
garyd1961
The shifter is not in the column correctly, I'll almost bet you. You are describing exactly what mine was doing when I first got it. Just knock the pin out and look up in the column you will see where it needs to go. Makes it hard to get in and out of park.
Old 08-24-2020, 11:37 PM   #14
LockDoc
LockDoc's Avatar
That won't do much good if you don't spray the top as I mentioned in post #4.
LockDoc
Leon
Old 08-25-2020, 08:47 AM   #15
vitamin_c95
LockDoc
As in inside the cab? Maybe I misunderstanding?
I read it again. I got you. Will do it again today. And the shifter thing very was talking about
Old 08-25-2020, 08:52 AM   #16
vitamin_c95
I'll check out
Old 08-25-2020, 11:07 AM   #17
vitamin_c95
I've had my 71 just over a year now. It was random seldom at first. Recently it's happened 3 times in a month. I've never had this column apart. So it's probably dried up and full of space dust. I will take this on tonight
