Old 08-25-2020, 05:24 PM   #2
Johns327
Johns327's Avatar
Re: Frame mounted Dual chamber Master cylinder for Drum/Drum..who's done it? Who like
Take a look.
https://www.brotherstrucks.com/47-87.../MSTR900/DRUM/
it may get you close to the drum/drum option you want.
If you put disc on you will need some form of power assist. Also consider a adjustable proportioning valve. The residual check valves are also a great add on.
There are other vendors out there as well that have upgrade kits.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
