Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-23-2020, 07:48 PM   #1
LT7A
Nutserts
A bit of conversation lately about products and available tools. After deft PMing and blatant build-thread hi-jacking I thought I would get the info corralled under its own thread header.
Old 08-23-2020, 07:54 PM   #2
LT7A
Re: Nutserts
I will start things off by saying that I'm on the lookout for a nutsert tool... I am installing mirrors on a couple of trucks where either the factory nutserts have deteriorated or the PO just drilled and screwed the mirrors into the door skin -- Splendid.
I hunted down the correct vinyl coated nutserts that the factory uses and I don't even remember where I found the information. I finally cornered them at I think Fastenal and had to buy a box. So if you need a couple...
I would like to get a decent installation tool without spending a whole C-note for just needing it a few times. I'm open to suggestions and would ask if anybody has had good luck with the HF version. I will copy a post over from SCOTI about a tool he found and we can get rolling from there if anybody else has interest in this.
Old 08-23-2020, 07:57 PM   #3
LT7A
Re: Nutserts
Originally Posted by SCOTI:
"I used the bolt & nut method after more than one instance where there isn't room for the tool pictured & the smaller rivet-gun style of tool wore my hand out after the 2nd or 3rd insert. Then, while @ my local 'premium' hardware outlet Elliott's, I found a set-up that's like the nut/bolt method but is easier to use. They were about $10 for each size needed.
Just to follow up on this.... I was asked in a PM about what I used/found @ my local 'premium' hardware joint. Here is an image of the set-up. I purchase one for each size I commonly use (1/4", 5/16, & 3/8). The nut-sert goes into the panel (keep the hole small enough so the inserts serrated edges grip the metal). The die slips over the bolt. Thread the bolt into the inset. As the bolt tightens, the die helps keep the insert from moving while it collapses the insert 'barrel'. They were less than $10 for each size. I put a dab of anti-seize on the bolt threads to prolong the thread life."
Old 08-23-2020, 08:00 PM   #4
LT7A
Re: Nutserts
SCOTI, thanks for the info. Did you find a manufacturer on the tool pictured or does your local hardware emporium have a website? That picture looks like it mighta got took from online somewhere. Since ATM I only need to pop in some 1/4 - 20s, buying an apparatus for each size is ok by me as long as it works well.
Old 08-23-2020, 08:10 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
Re: Nutserts
I have this unit and it works well....
Mandrel sizes included are
M5,
10-24,
M6,
1/4-20,
M8,
5/16-18,
M10
https://www.amazon.com/dp/B07XT5PF69...ustomerReviews
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-23-2020, 08:31 PM   #6
Thealien
Thealien's Avatar
Re: Nutserts
I bought mine at McMaster-Carr but they were not $10, probably closer to $30
Old 08-23-2020, 08:38 PM   #7
hatzie
Moderator
hatzie's Avatar
Re: Nutserts
I was going to suggest McMaster but you beat me to it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-24-2020, 09:20 AM   #8
SCOTI
SCOTI's Avatar
Re: Nutserts
That pic was from online but was a good image of the set-up so I used it. I intended to go by there this weekend (Sat) but had a funeral service to attend & didn't have time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-25-2020, 09:16 AM   #9
Honest Bob
Honest Bob's Avatar
Re: Nutserts
I bought this one but it looks like the price went up $30!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If you can wait, I would stalk woot.com they have had more than one sale on astro pneumatic stuff (I think?).
Honest Bob is offline   Reply With Quote
Old 08-25-2020, 11:38 AM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Nutserts
Here is an online source for the one SCOTI showed above, $15 each:
https://www.rivetsonline.com/rivet-n...et-nut-tools#1
These are a bit higher priced, but look to be built to last longer..
https://www.rivetsonline.com/rivet-n...ss-nut-tools#1
Here are a couple of other simple rivet nut installation tools:
https://www.aircraftspruce.com/catal...vetnuttool.php
6-32, 8-32, 10-321 thread sizes only
https://www.aircraftspruce.com/catal...onrivtool1.php
This one is limited on the thread sizes available, 1/4"-20 or -28 is the largest
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-25-2020, 03:08 PM   #11
layinrocker65
layinrocker65's Avatar
Re: Nutserts
I have one off of amazon. Was about $60, metric and standard sizes and came in a case. Couldnt find a link to the one I got but I’ve used it 100 times with sizes between 1/4 and 3/8 without a single issue.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 08-25-2020, 09:59 PM   #12
LT7A
Re: Nutserts
Thanks SCOTI, wasn't getting impatient. Wanted to get this out of Ryan's thread and was mystified how you had a picture and not a name, haha. Figured I would ask around and hit you back up for the mfr.
Old 08-25-2020, 10:08 PM   #13
LT7A
Re: Nutserts
Thanks to everyone that responded -- I have options! And an extra salute for all of the links!
BTW, I will pass along a little thing I discovered with amazon. They have been criticized for their "variable" pricing. It is "updated" 10 times a day. It seems to include an algorithm that tries to guess how much you want to buy an item.
An example: I had a couple of items up on tabs in my browser and put my computer into hibernate and went to bed. The next day I went to load up my cart and make the purchases but the items wouldn't load into the cart until I had refreshed the pages -- by which time BOTH items had gone up about 15%. Not a lot and probably geared to make me say "oh well" and pull the trigger anyway. Instead, I logged off amazon and left it for a day. Next time I pulled up those exact 2 items they were listed for LESS than they were priced WHEN I FIRST PULLED THEM UP. Crazy. Wouldnta believed it if I hadn't experienced it firsthand. FWIW.
Old 08-25-2020, 10:10 PM   #14
SCOTI
SCOTI's Avatar
Re: Nutserts
I went by there last night but they close @ 7p & I just missed. I've been working on my TRE insert debacle since after work so I didn't even try today.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2020, 10:08 AM   #15
ShortHaul
ShortHaul's Avatar
Re: Nutserts
FWIW I bought my nutserts at Fastenal. The tool I used was the Astro 1442... but I can’t fully recommend it as I had 2 out of the 12 nutserts fail to seat properly... could have been user error, but I felt like I used the same process for each one and ended up with different results twice.
LT7A thanks for creating the thread!
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 08-27-2020, 05:09 AM   #16
LT7A
Re: Nutserts
Thanks man! But no expectation whatsoever that you would head to the hardware store just to get information on this for me. I thought if you had it reasonably handy and it was stamped with a manufacturer, that then I could look into how to order one or buy one local. Please don't take any more trips just for this, but thanks so much.
Old 08-28-2020, 09:09 AM   #17
SCOTI
SCOTI's Avatar
Re: Nutserts
Additional info on what I started using when building my dually. These work well & you can do them in cramped spaces much easier.
I also purchased a Grade-8 bolt for each size die (insert tool nut) which is where my $10 number originated (die + bolt) combo. These were available/on the shelf @ my local Elliots hardware in the DFW area.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-30-2020, 10:03 AM   #18
hatzie
Moderator
hatzie's Avatar
Re: Nutserts
Real hardware stores that carry Midwest Fastener or Hillman are getting scarce.
Well worth patronizing real hardware stores that carry those kind of products rather than The Borg.
Old 08-30-2020, 12:44 PM   #19
SCOTI
SCOTI's Avatar
Re: Nutserts
Truth. My only complaint is the overly zealous 'help'. If I need to know something, I know how to ask. When I'm searching through bins looking for possible solutions, it gets annoying when they keep coming up to me w/the "What are we working on today?" opener.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-31-2020, 04:54 PM   #20
midnight rambler
midnight rambler's Avatar
Re: Nutserts
i got lucky and purchased 2 cherry max D-100-Mil-2 Hand Hydraulic Riveter from a buddy that retired. so far used it for installing blind rivets 5000 lbs of pulling force, what to try the dimple dies on it.
midnight rambler is offline   Reply With Quote
Old 08-31-2020, 05:34 PM   #21
LT7A
Re: Nutserts
Well, information doesn't get any more complete than that. Thank you SCOTI. I hope that wasn't the only reason you went there, but thanks again. It looks like a good solution for me. I have a similar type hardware store nearby but I don't know if they carry Midwest Fastener. Now I know what I'm looking for and can ask for if need be.
Old 08-31-2020, 05:36 PM   #22
LT7A
Re: Nutserts
I agree I don't know what I would do without their assortment of nuts, bolts, and other fasteners. Called McLendon Hardware in my neck of the woods and started by old man McClendon in the 1920s or so.
Old 09-01-2020, 11:31 AM   #23
Re: Nutserts
An important item for any tool...
Originally Posted by layinrocker65 View Post
and came in a case.
57NAPCO is online now   Reply With Quote
Old 09-01-2020, 12:11 PM   #24
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Nutserts
I am new at "working" with these. I am wondering is there a chart or a guide to tell a person what size hole to drill for the size of the revnut?
IE: 3/8-16 nutsert would need a hole=??
maybe i just missed it, not sure??
thanks!
rodstored-72 is offline   Reply With Quote
Old 09-01-2020, 03:38 PM   #25
SCOTI
SCOTI's Avatar
Re: Nutserts
thanks!
They make a 'Uni-Bit' style of step bit that is indexed (1, 2, 3, 4, etc) according to the Nutsert/Riv-Nut hole size. I don't know what the indexed sizes translate to mathematically.
I've just been using bits smaller than the nutsert being used. You want as tight a grip as possible so it's better to drill a smaller hole & file to size if necessary. I set the inserts I do to as a tight fit as possible which usually requires me to tap them in place w/a small hammer. Once compressed, they're locked in.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
