Old 08-20-2020, 07:16 PM   #1
Jmoney01
Nv4500 swap question
Assembling a 350 with a nv4500 for my 1980 GMC. Question, my current clutch rod goes into the drivers side. The nv4500 is on passenger side. How have you guys tackled this?
Jmoney01 is offline   Reply With Quote
Old 08-20-2020, 09:35 PM   #2
franken
Re: Nv4500 swap question
New BH or a hydraulic clutch are possibilities.
Old 08-21-2020, 10:31 AM   #3
mongocanfly
mongocanfly's Avatar
Yeah, you'll need to change bellhousing, or go to a hyd clutch...advanced adapters makes a bellhousing...
From experience...I would go with te hyd option
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-21-2020, 10:43 AM   #4
v30crewcab
v30crewcab's Avatar
you can redrill so your sm465 bellhousing fits the nv4500 as well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-21-2020, 05:56 PM   #5
kipps
Since your bellhousing has the low passenger side slave cylinder, it means you have the 92-95 nv4500. This nv4500 has the same size bearing retainer as the sm465, so you can modify the transmission to fit the sm465 bellhousing. If you're willing to drill and tap the transmission, this will be your cheapest and best option.
There should be a link to how to do this in the linked facebook file. Look for a link from 4btwaps.com.
https://www.facebook.com/notes/ls-sw...6984745739141/
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 08-21-2020, 07:22 PM   #6
Jmoney01
Thank you, sounds like a good route to me mainly because I'm cheap. Oh, and I have the parts. Guess I can sell the bh off the nv4500 when I'm done
Old 08-21-2020, 07:26 PM   #7
kipps
That 92-95 bellhousing is worth an easy $200 on Ebay, particularly if you can confirm that it doesn't have any cracks.
Old 08-27-2020, 01:10 AM   #8
Bob Q
I redrilled/modified the stock SM465 bellhousing when swapping a '94 NV4500 into my '83. I was able to retain all the stock clutch linkage with no problems at all. We're going to do this same mod to an '84 that we have too.
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
