Old 08-26-2020, 06:49 PM   #1
dave-68
Bed wood hits frame rivets
Anyone have their bed wood hit the rivets where the rear cross member ties to the frame? Is there supposed to be a spacer? I’m think about dimpling the wood but not sure I want to cut through the finish.
dave-68 is offline   Reply With Quote
Old 08-26-2020, 06:57 PM   #2
dave-68
Re: Bed wood hits frame rivets
Should of been more specific- are there spacers that go under the bed wood cross sills to raise the whole bed above the rivets?
Old 08-26-2020, 07:11 PM   #3
Old_Gold
Old_Gold's Avatar
It's been a while since I did mine, but I think there were either 4 or six bolts that attached the bed to the truck, and they had a small rubber pad for separation. I could take a peek later to confirm...
Jim
Old_Gold is offline   Reply With Quote
Old 08-26-2020, 07:34 PM   #4
dave-68
Thanks Old Gold! Mine’s a SB fleetside so there’s 8 bolts that tie the bed to the frame. Do remember if the rubber went between the sill and frame or sill and wood?
Old 08-26-2020, 07:36 PM   #5
Old_Gold
Old_Gold's Avatar
I was thinking it was on the frame, but may have to check on that!
Jim
Old 08-26-2020, 07:54 PM   #6
70'
70''s Avatar
You have to use a Forstner bit on the bottom side to make a clearance recess over the rivets.
70' is offline   Reply With Quote
Old 08-26-2020, 08:06 PM   #7
dave-68
‘70 thanks. That’s what I was going to do. Just wish I would have caught it before finish. No worries, got plenty of finish left. Not that it matters much but do you know if that was done that way from the factory?
Old 08-26-2020, 08:14 PM   #8
70'
70''s Avatar
Dave,
I can't speak to that, but I am sure someone on here knows.
Old 08-26-2020, 09:14 PM   #9
Old_Gold
Old_Gold's Avatar
Ok, must not have used any spacers, but don't remember any clearance issues with riveted. Here is what I have:
Jim
Old 08-26-2020, 09:29 PM   #10
dave-68
Jim
Thanks. All kinds of mystery fit ups with this one. I blame most of it on the aftermarket stuff I bought years ago.
Old 08-27-2020, 02:03 AM   #11
mr48chev
mr48chev's Avatar
https://www.classicparts.com/1954-87...ctinfo/13-556/
My ongoing truck projects:
Old 08-27-2020, 07:15 AM   #12
dave-68
Originally Posted by mr48chev View Post
Thanks. I read about guys using these and some that didn’t. They might work as long as there thick enough and don’t compress too much. Weird I couldn’t find anything about the bed wood assembly in the factory assembly manual.
Old 08-27-2020, 09:16 AM   #13
72c20customcamper
72c20customcamper's Avatar
There were no spacers on mine when I disassembled it. Original wood in bed had no issue with the wood hitting
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-27-2020, 09:31 AM   #14
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Steppers have a rubber pad that goes between the frame and bed available. Not sure about the fleets.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
