Old 06-30-2020, 09:13 PM   #776
IronCanine
I'm trying....
IronCanine's Avatar
Re: 67 GMC super custom build
'Awesome'? 'Ford'? My good sir, I must protest.
IronCanine is offline   Reply With Quote
Old 06-30-2020, 09:55 PM   #777
chewychevy67
Yeah I know. But ford used the exact same speed sensors in 1969-73 for their cruise control as gear vendors does so the bracket was taylor made for that sensor and looks completely like it should be there. I know it's still a Ford part. At least it doesn't have a fomoco part number stamped into it. I would have had to fill it over.
chewychevy67 is offline   Reply With Quote
Old 06-30-2020, 10:13 PM   #778
IronCanine
I'm trying....
IronCanine's Avatar
You may save your rationalizations. A straw fits perfectly in my nose, but as a method for drinking, it leaves much to be desired. You have gone too far this time my friend. This is MADNESS!!!! MADNESS I SAY!!!!
Old 06-30-2020, 10:23 PM   #779
Wide Open
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-03-2020, 09:56 PM   #780
chewychevy67
If there's one thing I hate it's having metric bolts on my 67. My new ac compressor came with metric threads for the front bolts. I tapped them to sae threads. I'll be putting the original style decal on to cover these when it's completed.
Old 07-17-2020, 01:23 PM   #781
chewychevy67
Got my new engine drive belts. They are just as the originals were cloth wrapped and stamped with the gm part numbers.
Old 07-17-2020, 02:44 PM   #782
IronCanine
I'm trying....
IronCanine's Avatar
Now that's what I'm talking about! Looking good.
Old 07-17-2020, 03:50 PM   #783
chewychevy67
I didn't even know these existed till you posted them on your build. It's a nice touch for a fresh engine
Old 07-21-2020, 02:00 PM   #784
chewychevy67
Although I love my original hub caps and radial tire look (which I'll never sell) I purchased a set of these with the blank small 67 center caps. I'm going to have my cnc guy make me a gmc center to mount in the smooth part of the center cap. They do make the tall centers now with the words " general motors corporation" but I'm not sure I like the tall cap look. Just don't want a bowtie on my gmc
Old 07-21-2020, 02:34 PM   #785
Kronald_70GMC
Kronald_70GMC's Avatar
That will look pretty awesome!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 08-27-2020, 06:37 PM   #786
chewychevy67
Got me some Nos rockers locally!
Old 09-01-2020, 05:56 PM   #787
IronCanine
I'm trying....
IronCanine's Avatar
Dyn-o-mite!
Old 09-03-2020, 05:59 PM   #788
chewychevy67
It's goona be slow for a bit here now. Petty much all that's left is the metal and paint but nuke1 closed up shop so I'm looking for a new "quality" shop to do the work. I don't want to waste all my Nos pieces on an amateur again.
Old 09-15-2020, 08:22 PM   #789
chewychevy67
I picked up one last option to put on the 67 before metal work starts. It is the hd air cleaner. It requires I change my air cleaner. I may try to adapt the snorkel into my existing one but we'll see. I'm just missing the hose that goes from the air cleaner to the pre-cleaner if anyone has one to sell. Also picked up a gm tissue/litter container. I'll be matching it to the interior color.
Old 09-25-2020, 07:29 PM   #790
chewychevy67
I got the pre cleaner yesterday. It has a flap in the inlet that is operated by a spring. When not moving it must suck air from the engine bay and when your driving the air forces the door with the spring down and closes off the air inlet to the engine bay. I wonder if I could get this decal off without ruining it?
Old 09-25-2020, 11:16 PM   #791
TA_C10
TA_C10's Avatar
Heat to the backside and then a razorblade underneath. I've removed stickers like that. Takes a while. Something else that can help if the sticker isn't paper, is goo-gone. That stuff under the sticker will take the sticky off like butter.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 09-26-2020, 03:17 AM   #792
chewychevy67
Ok I will try that possibly on a decal on another cleaner first. Have you successfully reused one after removing it?
Old 09-28-2020, 10:08 AM   #793
TA_C10
TA_C10's Avatar
Yes if it's not paper
You can use the same glue for headliner to make it stick and not be permanent. Or if it goes somewhere where it will get wet, make sure to use something water resistant.
"It's only money".
Old 09-28-2020, 11:31 AM   #794
IronCanine
I'm trying....
IronCanine's Avatar
Not that I really want to get another decal project going, but I'm happy to help if it doesn't come off cleanly. You know I like this project.
Take careful measurements before you attempt removal...that's always helpful. If there is not a good reproduction version currently available, it shouldn't be a particularly difficult one to do (if you want).
Old 09-28-2020, 06:43 PM   #795
chewychevy67
If I can't get it off I would like to have another made. I will take good measurements just in case. Probably do it on the weekend coming up
Old 09-28-2020, 07:07 PM   #796
IronCanine
I'm trying....
IronCanine's Avatar
I've got your back. Even if it tears, take your time and get as much as you can in the best condition possible. Even pieces make it easier to remake.
EDIT: After a quick internet search I found a lot of these decals, just no 6420553s.
Old 09-28-2020, 08:42 PM   #797
chewychevy67
Yeah I couldn't find the correct part number either
I'll keep you posted if this comes off clean or not
Old 10-01-2020, 08:53 PM   #798
chewychevy67
Got it off unharmed!
Old 10-01-2020, 08:55 PM   #799
IronCanine
I'm trying....
IronCanine's Avatar
You're a surgeon. Well done.
Old 10-17-2020, 06:31 PM   #800
chewychevy67
Well it's all about the details around here. I finally found the correct cast iron pulley for the 67 air injection. I've seen 2 factory smog 327 trucks and they both had the cast iron pulley. Last pic is the only photo I have of an original still on a truck.
