let me check if i understand correct. you got some bolts with a square head and welded the square head in place of the hole in the bumper? you welded from the back of the bumper right? and then you used the bolt to bolt in on the brackets. did you weld the brackets to the bumper as well or are they just attached to the bolt thats been welded to the bumper?
i think id like to use your idea as well as my idea as well and use the square headed bolts and weld the bracket to the bumper for extra support. AND YES I WOULD LIKE SOME PICTURES dropt72shortbed@aol.com [This message has been edited by dropped72shortbed (edited March 21, 2002).]
Blake A. - Huntington Beach CA 72 c10 swb 5/5 drop, 350/350, partialy shaved, soon to be 5/7 on 20s. |
| Bookmarks |
