#51 |
Re: 1990 V2500 Suburban Build Thread
It looks incredible!
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
#52 |
![]() Join Date: Mar 2003
How many sq ft of the rattle trap did you go through to do the top and bottom?
#53 |
#54 |
Today I started the engine swap on my suburban
First Pic is "PREOP" before it went into the shop. Second pic is of all the parts delivered to the shop. |
#55 |
Here is the after the first day of work
#56 |
Prepping the LS3
#57 |
#58 |
Day number two,
Got the engine and gas tank out. Changed the fuel pump and fuel sender. Also made a bracket for the Gas pedal to bolt in. I also removed all the TBI wiring. I removed the oem cross piece and put in a ORD unit and realized the ORD unit would not work with the oil pan I have but the oem one will. So I will stick with the oem one. |
#59 |
#60 |
I have decided to not put the LS3 in and instead install this engine. Of course I need to come up with another $60K for this engine.
#61 |
Here is a picture of the complete car, This car is for sale, just $700,000.00 ( Car sold and was shipped to new owner while I was there)
It has a Shelby Serial number. Last edited by Ryan Hubbard; 09-13-2020 at 08:19 PM. |
#62 |
chevy truck fan
uuhmmm
#63 |
LS3 Installed
#64 |
chevy truck fan
ryan,
that looks alot ..... more better! ![]() ![]() |
#65 |
Nice looking burb!
#66 |
![]() Join Date: Apr 2018
Wow. This is amazing. You tear down, bodywork, paint, reassemble and LS swap your burb in the time it takes me to find a set of rear view mirrors
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
#67 |
Just here to tinker
![]() Join Date: Jun 2008
Great work and beautiful burb!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#68 |
Engine is finished and last Thursday I drove the Suburban from Provo, UT to So Cal to do the "break-in" of 640 miles. I am really happy with the set up. I have been tuning the transmission and have it almost done to my liking.
#69 |
chevy truck fan
ryan,
looks very good & that is a heck of a break in drive!! nice job!! would you be willing to share what you did for wiring... aftermarket or ??? again nice job!! |
#70 |
The LS3 E-Rod comes with everything, the wiring harness, the computer and the power center. It was real easy to install the wiring. The computer and the "power center" were a little tricky to find where to mount under the hood.
#71 | |
chevy truck fan
.. I ask because I am doing a LS swap in my '86 and I am trying to use the factory underhood fuse box & harness from the donor truck. I was not able to get the whole vehicle ![]() would you be willing to post pic(s) of the harness and power center by chance? |
#72 |
Great work on this gorgeous truck! Where did you get the intake tube?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#73 |
Here is the following list of parts I used for this LS Swap with:
NAL-19370414 Chevrolet Performance LS3 E-Rod Crate Engine CMB-03-0263 LS Fuel Filter Kit Black DAK-CRC-200-3 Dakota Digital Cruise Control Kit HLY-20-143 Holley Accessory Drive Component Mount w/Alternator and PS Pump HLY-20-133 Holley A/C Bracket HLY-21-1 Holley LS Engine Accessory Drive Kit ICB-551600 Oil Cooler Adapter SPE-900235 Spectre Air Intake Kit Dirty Dingo 73-87 4WD Chevy LS Engine Mounts Dirty Dingo E38 Gen IV PCM Billet Mounting Plate Spintech 8000 Truck RV Muffler AP Exhaust X6008 Mandrel Bent 3" tail pipe Earl Fitting 961956ERL Power Steering Fitting Earl Fitting 961961ERL Power Steering Pump Fitting |
#74 |
Here is a picture of the power center and ecu mounted
#75 |
Well since the last post I have driven the Suburban 30,000 miles and I can say the thing works great. I moved from So Cal to Utah and towed my enclosed car trailer behind the suburban every round trip.
I did lose overdrive with my 4L80E but I had one day left on the warranty for my transmission so it was rebuilt under warranty. I have really dialed in the transmission and added the Dakota Digital cruise control and it made the long trips really nice to drive. |
