Old 08-31-2020, 09:35 PM   #6
68PanelTruck
68PanelTruck's Avatar
Re: Where can I find this part?
Originally Posted by Dieselwrencher View Post
That stinks it is different but that's probably the closest you're going to get for a new panel. I think I'd cut out your sun visor raised area and transfer it to this new panel. Maybe the center holes are the same and you can locate the old pieces on the new panel that way? You could probably cut the top rolled part off and cut your new panel and add it to it as well. Then it would look oe.
Good idea, I didn't think of that. It really depends on what condition the original is in after I get it out of the truck. The visor holes look the same size and I'd bet they would work but I like your idea better. Thanks.
It's not rust, it's called patina
Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust.
68PanelTruck is offline   Reply With Quote
