Was your dash cut / hacked for a stereo? Here's a solution: Awesome Storage Box
Over the past 8 months, I've been fixing up a mostly original 72 K10 that will soon (hopefully) be my patina'd daily driver / work truck. Trying to keep it mostly stock but I've made a few small changes that I think make it more practical. One issue that I had is that it came with an old CD player, and the dash had been cut for it. Who needs a stereo these days when you can just use your iphone to bluetooth to an external speaker?!
So I thought, I'm gonna make that hole into a *****in' storage box to put my phone when its plugged into the cig lighter to charge, to throw spare change in, etc, etc. So I removed the stereo and cut the hole out nice and even, and then I made a cardboard template until I got the box just the way I wanted it. After that, it was off to a local fab shop to have them make a 'copy' of my prototype out of stainless steel. I bolted it in place with some nice button head allen bolts and used a bit of transmission pan rubber gasket between the box and the SS backing plates I made so that it wouldn't have any wiggle or vibration issues. I couldn't be happier with how it turned out! I think it looks great, its super stout, and is the perfect size to hold 2 iphones side by side (last pic of the pink phone is the wife's), and really adds some practical storage to these trucks which don't have a ton to begin with. This may have been done before, but either way, just thought I'd share! |
Re: Was your dash cut / hacked for a stereo? Here's a solution: Awesome Storage Box
More pics
The last of em
Might want to put a 1/16"lip on the bottom edge so when you hit a speed bump or pothole the phone stays put.....
It’s got a downward slope into the box so hopefully it stays put!
![]() Join Date: Feb 2019
Put piece of that shelf lining material in there and it will keep things from sliding around, works great for RV cabinets too.
https://www.bedbathandbeyond.com/sto...E&gclsrc=aw.ds
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
![]() Join Date: Nov 2010
Looks good. How much did it cost you. If your willing and able to have another one made I’d be a buyer. Thanks much i think it’s a good idea
Some progress is better then no progress |
![]() Join Date: Apr 2008
Very nice fabrication skills
71 C10 72 K20 72 K10 Super Kirk |
![]() Join Date: Dec 2013
OH NO , You removed the AM radio flux capacitor ? It will never run right again ...
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
What are you going to do for tunes?
Oh, I re read your post and see you are using Blue Tooth speakers. My bad.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 08-30-2020 at 10:07 AM. |
Well done looks good. The slope should keep things in place for DD. If not add the rubber shelf material. My dash was hacked up the same way but I put it back to OEM spec.
One question is where are you going to mount your BT speaker(s)?? |
![]() Join Date: Nov 2018
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
That looks really good. Dang if your dash doesn't look exactly like mine except I've still got the CD player. I'm old. I never got the whole Bluetooth thing. My wife has it in her car and she uses it all the time. It just seems complicated to me. I just shove in a CD and call it good. She says I'm a dinosaur. And she's probably right.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#14 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#15 |
![]() Join Date: Aug 2004
Nice idea! I never thought of that.
A hinged delete plate could be used also, to make it a little hideout cubby.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#16 |
![]() Join Date: Dec 2009
Nice Job.
#17 |
![]() Join Date: Aug 2008
Great idea! To add to this, how about attaching one of the wireless chargers from a newer car in order to charge the phone while it is in the box?
#18 |
Glad you guys like it! I can tell from all the additional ideas I got y'all screws turning!
If I really wanted to be slick, I could mount a hidden kill switch way in the back and then throw some sunglasses or junk in front to hide it...ideas ideas For tunes, I just throw my little bluetooth speaker up on the dash and wedge it against the window, good spot for broadcasting the sound waves from up there. If it gets too bumpy then just chuck it on the seat The box was pretty pricey, I had a local fab shop make it. Ran $275 total. It took them a few hours, they could have made it cheaper and cruder, but making it look nice and not distorting the thin gauge metal took some time. I thought the price was fair, time is money and nothing's free, a new stereo would probably cost that, and this thing will outlive me! |
#19 |
#20 |
Ding ding ding! You win!
#21 |
Looks really nice. For those on a more limited budget, a car stereo shop can get a DIN size pocket that will fit that hole..
#22 |
nice job on filling the hole, good idea
