Old 08-28-2020, 03:35 PM   #1
Keith6987
Hole ID
What are the bumpy holes in front of the front bump stop brackets used for?
Keith6987 is offline   Reply With Quote
Old 08-28-2020, 05:28 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Hole ID
Maybe brake hose? Don't have mine to confirm at the moment.
Old 08-28-2020, 05:32 PM   #3
Keith6987
Re: Hole ID
When I disassembled it, the brake hose was in the hole to the rear of the bump stop. I don’t know if that was the correct place or not.
Old 08-28-2020, 05:46 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Hole ID
Could be correct I can check at home if no one else chimes in.
Old 08-28-2020, 06:00 PM   #5
litebulblsc
litebulblsc's Avatar
Re: Hole ID
Might have to ask a previous owner that question.
And I do believe my brake line is suppose to be down a hole
litebulblsc is offline   Reply With Quote
Old 08-28-2020, 07:06 PM   #6
Keith6987
Re: Hole ID
My frame is a 69 and the axle is a 72. So maybe when It had drum brakes the hose came out in a different location?
Old 08-28-2020, 07:28 PM   #7
litebulblsc
Re: Hole ID
Mine is a '72 and yours does not have the same brake line hole mine has. So you may be on to something
Old 08-28-2020, 08:15 PM   #8
Tmend
Tmend's Avatar
Re: Hole ID
I have a 72 frame
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 08-28-2020, 08:19 PM   #9
Tmend
Tmend's Avatar
Re: Hole ID
Attachment 2044091
Attachment 2044092
Old 08-29-2020, 09:29 PM   #10
davischevy
davischevy's Avatar
Re: Hole ID
Yes the drum brake trucks had the line in a different location that the 71 72.
My 72.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-30-2020, 10:27 AM   #11
1rippen6
Re: Hole ID
I converted a 70 to disc brakes and had to drill the hole in the frame for the brake hoses.
1rippen6 is offline   Reply With Quote
Old 08-30-2020, 11:01 AM   #12
Keith6987
My 72.
Old 08-30-2020, 03:44 PM   #13
Keith6987
Re: Hole ID
Thanks for the replies. I wanted to confirm before I started making hard lines. To be honest there are a lot of frame holes that I can’t ID yet.
Old 09-04-2020, 03:31 AM   #14
Harold Holbrook
Re: Hole ID
Nice work, Hope to be there at the end of month .
Harold Holbrook is offline   Reply With Quote
