Old 09-03-2020, 03:53 PM   #1
hooverfish
hooverfish's Avatar
Help: Under Hood A/C Actuator (for fresh air door)
Ordered a new Actuator and the center metal arm spins around, it is not in a fixed position.
Installed it, when it's actuated it jumps out of the arm on the firewall.
Sent it back, got another one from another supplier, same problem.
Original that came off the truck has fixed arm.
So, do I have to wire this thing together ?? Anyone else experience this problem ??
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 09-03-2020, 04:54 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Help: Under Hood A/C Actuator (for fresh air door)
Pretty sure that is supposed to have a push nut on it.
https://www.google.com/search?q=push...hrome&ie=UTF-8
~Steven
Simi Valley, CA
Old 09-03-2020, 06:30 PM   #3
hooverfish
hooverfish's Avatar
Thanks for the suggestion. I looked at the Assembly Manual for the 2nd time and now see that yes there is supposed to be a nut.
I put a 'speed nut' on it and it seems to be holding.
Thank you for your help !
Larry
Old 09-03-2020, 06:39 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
You're quite welcome!
~Steven
Simi Valley, CA
Old 09-03-2020, 07:14 PM   #5
FirstOwner69
FirstOwner69's Avatar
Here's a picture.
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-03-2020, 07:45 PM   #6
hooverfish
hooverfish's Avatar
Originally Posted by FirstOwner69 View Post
Here's a picture.
Thank you, excellent photo.
Larry
Old 09-03-2020, 11:52 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice to have that photo! Mine needs replacing, but the push-nut was missing right off the bat. Moot point, since the vacuum line was disconnected. My FiL did a lot of MM stuff that I'm slowly back out of the thing.
~Steven
Simi Valley, CA
Old 09-04-2020, 07:36 AM   #8
hooverfish
hooverfish's Avatar
Steevee, I ordered a tiny assortment off Ebay for $7.
Think I will have an extra of correct size, if so I will drop one in the mail to you, if you want.
Larry
Old 09-04-2020, 11:27 AM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
I appreciate that, but I have some already.
By replacing, I meant the valve. I have yet to go buy it.
~Steven
Simi Valley, CA
