Old 09-04-2020, 06:25 PM   #1451
70C10Dude
Re: What did you do to your truck today.The 3rd chapter
Just put some lowering spindles on mine today! What a Pain in the neck.
70C10Dude is offline   Reply With Quote
Old 09-04-2020, 08:47 PM   #1452
Richard2112
Richard2112's Avatar
Put in a stereo
Richard2112 is offline   Reply With Quote
Old 09-04-2020, 11:29 PM   #1453
rechinca
rechinca's Avatar
Finished up the inner lower cowl repair. Got to as much bare metal as possible, had to use a little rust convertor, then hit the whole section with Eastwood Platinum Encapsulator. Hopefully that helps seal up the metal and seams/welds. Nothing like learning to weld and a lot of rust repair! At least the ugliness of lessons learned are hidden!
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 09-04-2020, 11:39 PM   #1454
68PanelTruck
68PanelTruck's Avatar
I'm right there with you. I recently picked up a 68 Panel with rust issues. I'm also learning to weld and started on the cowl area too! If you can weld thin rusty metal, everything else is easy, lol.
It's not rust, it's called patina
Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust.
68PanelTruck is offline   Reply With Quote
Old 09-05-2020, 02:00 PM   #1455
fourspeedwagon
fourspeedwagon's Avatar
Trying to figure out what these are? They are bolted to the frame on each side near the motor mounts.
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
Old 09-05-2020, 03:14 PM   #1456
HotWheelsFan
HotWheelsFan's Avatar
Got the truck running again. Been sitting for 8 years.
No longer have room to keep it anymore. Needs a little work from sitting... Has lifter noise, needs wiring repairs, and a good cleaning up.
Still drives very nice, hate to see it go.
HotWheelsFan is offline   Reply With Quote
Old 09-05-2020, 05:29 PM   #1457
3757chevy
3757chevy's Avatar
My guess is they are splash guards?
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 09-05-2020, 06:01 PM   #1458
Grumpy old man
Grumpy old man's Avatar
exhaust manifold cooling ducts .
Old 09-05-2020, 08:49 PM   #1459
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
x2....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-05-2020, 08:59 PM   #1460
fourspeedwagon
Is that something factory? (Assuming you weren’t joking)
This truck, despite having come to me without an engine, seems to be pretty clean and original. Even the little exhaust manifold bolt “clips” were still sitting on the cowl from when the engine was pulled (no idea why the engine came out— maybe blew up, maybe it went into something else?) The outside paint is super sun baked and faded but the interior makes me believe the 20,xxx shown on the odometer is probably only rolled over once
1968 Suburban C10
1971 C20 Olive
Old 09-06-2020, 08:08 PM   #1461
jimijam00
removed the seat, 2pt belts, and the fuel tank.
jimijam00 is offline   Reply With Quote
Old 09-08-2020, 05:14 PM   #1462
72c20customcamper
72c20customcamper's Avatar
Sanded the roof going to paint in a few days roof will be off white . Now I have to back tape everything I just painted . The tape is starting to add up . Good automotive tape is outrageously priced but the regular box store stuff dont work. At least the bug decided to land in an area not seen
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-08-2020, 05:19 PM   #1463
72c20customcamper
Reason I'm delaying the roof paint going to try and look at this truck. But it will be an overnight trip.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-13-2020, 07:29 PM   #1464
72c20customcamper
Did the roof today . Came out good but could be better. Going to sand it in the morning and reshoot it
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-13-2020, 07:31 PM   #1465
72c20customcamper
Taping is a real pain in the ass
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-13-2020, 07:44 PM   #1466
Boog
laying low
Boog's Avatar
You are spraying everything outside I see. What's your paint? Acrylic enamel or bc/cc?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-13-2020, 07:53 PM   #1467
davischevy
davischevy's Avatar
Yes, they are factory.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-13-2020, 08:32 PM   #1468
72c20customcamper
I did it under a cover it . Then moved it( the cover it) so it could bake in the sun
But my go to is single stage PPG paint for solid colors
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-13-2020, 08:37 PM   #1469
72c20customcamper
B/C For the rest of the truck I am using a booth.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-13-2020, 08:46 PM   #1470
Boog
laying low
Boog's Avatar
I did body and paint work 45 years ago. Things sure have changed. My favorite was acrylic enamel. It flowed out so nice and had the shine without cutting and buffing. Is AE even still available? I have not kept up with paints and supplies since I got out of it.
Boog
primer is finer
Old 09-13-2020, 09:01 PM   #1471
72c20customcamper
I have some centari acrylic paint can't get the reducer any more let alone the hardener that came out towards the end real good isocyanates. It was good in the day but the new stuff is incredible. Dries like the old lacquer and gets hard as a rock in a few hours
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2020, 01:47 PM   #1472
72c20customcamper
Reshot the roof it's acceptable now .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2020, 01:53 PM   #1473
72c20customcamper
Top
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2020, 03:43 PM   #1474
pjmoreland
pjmoreland's Avatar
Finished up a brake booster installation. Removed the engine harness so I could unwrap it, extend the brake sensor wire by 9" under the wrapping, and re-wrapped and installed it. Not sure I routed the sensor wire the correct way. Seems a little precarious where it is. Also painted and installed a choke delete I got from daddymoo2. It's nice to have that hole covered up.
Finished cleaning up the passenger side inner fender yesterday. Had to weld in a little patch to fix some rust at the brace. Will be doing the other side next.
pjmoreland is offline   Reply With Quote
Old 09-16-2020, 04:42 PM   #1475
BC10
BC10's Avatar
Originally Posted by Richard2112 View Post
Put in a stereo
Dang son!
BC10 is offline   Reply With Quote
