Old 09-05-2020, 12:14 PM   #1
1-PU70
1-PU70's Avatar
Electric Fuel Pump Relay
Im Installing an electric fuel pump with a relay. The pump will be mounted on the frame by the original in cab tank. My question is where have you been mounting the relay. I can mount on the fire wall or by the pump or by the battery.
Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 09-05-2020, 01:08 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Electric Fuel Pump Relay
I mounted mine on the firewall next to the heater box. I routed the 10ga. red wire over the heater box and then forward across the top of the inner fender to the breaker fuse, and then from the breaker fuse to a positive terminal block. I mounted the breaker fuse and terminal block to the fender right next to the black factory terminal block. The instructions for my fuel pump indicated locating the breaker fuse close the battery and the pump as close and lower than the tank. Locating the relay someplace between the two out of the way of rain and road spray. I ran my yellow trigger wire right off the keyed 12 volt power spade on the fuse block. I also added a switched power supply to a toggle switch in the dash.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-05-2020, 03:08 PM   #3
dmjlambert
dmjlambert's Avatar
I recommend adding an oil pressure shutoff switch for the fuel pump relay, to cut it off in the event of a collision or other problem that stops the engine.
Old 09-05-2020, 03:19 PM   #4
HotWheelsFan
HotWheelsFan's Avatar
I agree with the oil pressure cut off. Should be easy to install.
Bob
HotWheelsFan is offline   Reply With Quote
Old 09-05-2020, 05:37 PM   #5
gmc684x4
Ron francis has a inertia cuttoff switch
https://www.ronfrancis.com/prodinfo.asp?number=CR-92
gmc684x4 is offline   Reply With Quote
Old 09-05-2020, 05:49 PM   #6
HO455
HO455's Avatar
I used one of these.
https://www.revolutionelectronics.co...Fuel_Pump.html
https://67-72chevytrucks.com/vboard/...=698377&page=6. Scroll to post 127 and below.
As far as the relay mounting look for some place dry, with good visual access, for when you have to replace it along the road on a dark and stormy night.
RIP Bob Parks.
