09-02-2020, 05:32 PM | #1 |
6-7 Blade Fan Part Number/Source
Upgrading from my non-clutch 4 blade on my 72 GMC K1500.
Read through some threads but couldn't find a source for the actual fan blade (Hayden has stopped selling fan blades). Planning on buying the Hayden 2705 thermal fan clutch and looking for a 6 or 7 blade fan go with it. Does anyone have a part number or source they have used in the past? TIA |
09-02-2020, 05:39 PM | #2 |
Re: 6-7 Blade Fan Part Number/Source
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
09-02-2020, 06:15 PM | #3 |
Here's the one I use on my 72 with stock fan shroud with a clutch and rotates clockwise(since I have v belts).
https://www.summitracing.com/parts/DER-17118 |
09-02-2020, 06:26 PM | #4 |
I used a Derale 17118, 18" Rigid fan, clutch type, 6-blade (just saw it's the same fan used by roboticjunky). Summit P/N DER-17118 along with a Hayden 2705 thermal clutch fan from RockAuto.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
09-02-2020, 07:04 PM | #5 |
20' Daredevil (Ret)
FWIW, I love my factory 7-blade fan. I would assume replicas are every bit as good, or you might find an OEM unit in a salvage yard or maybe find a board member with one to sell you.
If I may make a suggestion as to the clutch unit. A few years ago mine failed and my research came up with something. Hayden #2705 is a light-duty unit. One way to tell is the fins on the face are just around the outer edge. With factory A/C, my thermal OEM clutch was a heavy-duty unit (fins covered most of the face) and I found that a Hayden #2747 is a perfect replacement. My fan has 2 1/2" pitch, so a light-duty clutch would not be correct. Whether you have A/C or not, in Texas heat you might benefit from the additional cooling capabilities of a HD fan clutch. From Hayden's site: https://www.haydenauto.com/en/techni...q-fan-clutches • Standard Duty Thermal: Turns the fan 50-60% of shaft speed when engaged. Used with fans with lighter pitch (1-1/2" of pitch). Flat plate impeller design with 30 sq. in. of working surface. • Heavy-Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged for increased cooling. Used with deeper pitch fans (2 1/2" of pitch). Land and groove design with 47 sq. in. of working area allows higher operating RPM's. • Severe Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged. Used with deeper pitch fans. (2- 1/2" of pitch). Land and groove design with 65 sq. in. of working area. Larger working surface provides cooler running and longer life expectancy.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 09-03-2020 at 01:04 AM. Reason: added info |
09-03-2020, 10:33 AM | #6 |
Thanks for the quick replies everyone! I think I'll take you're advice on the fan clutch Stoker and see if I can find a NOS or OEM 7 blade first. If not, I'll go after the others that were listed.
Thanks! |
09-03-2020, 11:21 AM | #7 |
Not sure if this is what you are looking for, but I have this one I will be taking off this weekend in case this works for you.
09-03-2020, 01:43 PM | #8 | |
Let me know and thanks! |
09-03-2020, 02:44 PM | #9 |
09-03-2020, 07:18 PM | #10 |
The repop 772 fan, is an 18" fan, and a great match with the Haden 2747, or the 2947 if you need to pull the fan closer to the block to ensure the blades are 1/2 in and 1/2 out of the shroud.
09-05-2020, 11:14 AM | #11 |
Mine looks to be the repop 3947772.
09-05-2020, 11:27 AM | #12 |
20' Daredevil (Ret)
I wondered if it might be a repop..... in your earlier pics it didn't seem to look quite like an OEM fan.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-08-2020, 11:39 AM | #13 |
09-08-2020, 12:14 PM | #14 |
