06-05-2020, 07:50 AM | #1 |
getting the shaft! drive shaft that is
Ok guys and gals,
I have a 67 with the you ruined it 6.0 4l80swap. I'm currently running the stock 2" drive shaft that worn torn and needs to go. a friend has a donor Express van and said I could have the shaft out of it. Will probably need to be shortened. now being budget minded I thought this would be a good idea seeing the shaft shop local quoated me 700 for a 2piece and 150 to shorten a shaft. I see a lot of people have dumped the 2 piece and had shafts made. what's the general census. my set up and use for the truck= 6.0 vortex 4l80e 245/65r17 tire 3.73 rear end. (will end up with a locker or posi) mostly a daily driver with occasional weekend shenanigans. |
06-05-2020, 09:12 PM | #2 |
Re: getting the shaft! drive shaft that is
Unfortunately for you there is no general consensus on this subject. Do a search of the dozen or more debates across all the 60 to 72 forums. You will have to pick your path then do your research.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-05-2020, 09:24 PM | #3 |
I would say find out how much clearance you have for a possible 1 peice drive shaft
The truck arm cross member is the limiting factor as the drive shaft has to fit through it which is not a factor on a leaf sprung truck When setup you can corner much better with a truck arm setup |
06-06-2020, 01:33 PM | #4 |
I have been considering the same thing, and have a few aluminum drive shafts saved as possible donors.
________________ 1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd. 2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold} 1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400 2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax. |
06-07-2020, 07:47 AM | #5 |
my 72 Cheyenne LWB had a single shaft installed by the PO 402/700r4 he modified the OEM trailing arms crossmember to take the angle of the single shaft .......would be my choice
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-07-2020, 02:41 PM | #6 |
Here is a cross member replacement that I found
https://pbfab.com/1963-72-trailing-a...ece-driveshaft |
06-08-2020, 09:14 AM | #7 |
Save the $550 for other go fast goodies.
09-09-2020, 03:24 PM | #8 |
I had one built by action machine for 465 shipped to me. i went from a 2pc on a long bed to a 1pc
09-09-2020, 05:32 PM | #9 |
Locker on street driven trucks suck go with a posi you will be happier
Lockers are built for off road use hard cornering with a Detroit lockers can produce a heck of a bang af it disengages and re engages I have them in one of my 4x4 trucks my two wheel drive truck is getting a posi |
09-09-2020, 05:52 PM | #10 |
Local driveshaft shop $400 to change my 2 pc to a 1 pc.
He didn't reuse anything but the yoke out of the 700r4. Blakeslee |
09-09-2020, 09:05 PM | #11 |
Old member
71 C 10 with 2004 HD 6.0 /4L80E and had the 2 piece swapped for a 1 piece. Love it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-09-2020, 11:13 PM | #12 |
Give Tom Woods Driveshaft a call.
Very good people to work with as well. Pat |
09-10-2020, 11:56 AM | #13 |
I considered a 1-pc when I converted to 4L80E on a long bed C20. Unfortunately, I found that the driveshaft would contact the trailing arm crossmember with suspension at full droop. The driveshaft shop suggested cutting away a portion of the crossmember. I pointed out that the crossmember is a structural piece through which all push from the axle flows to the main frame of the truck. Not a chance I would cut it up without adding metal to regain the strength and stiffness that was lost. That sounded like too much custom work and so I simply had the forward shaft shortened, a new TH400 yoke installed, along with all new joints and a new carrier bearing (which I welded the attachment pad along the sides). I think all this cost about $275 with balance. Works great!
DO NOT USE A URETHANE HOUSED CARRIER BEARING!!!! The bearing must be housed in rubber so as to allow the slip yolk to move in and out of the transmission as the suspension goes through its trailing arm arc. I can't understand how anyone thought the urethane was a good idea.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
