Old 09-10-2020, 03:56 PM   #1
SCOTI
SCOTI's Avatar
Re: Project: Recycle
Originally Posted by raylube View Post
Times 2 . I have not yet had time to fully check out this build but glancing over it you have skills way beyond everything I have seen. When I get done with my 4x4 project I will definitely use your build as the idiot's guide to chassis work lol on my 2wd trucks. Keep up the good work
As you're aware, my recent requests & our conversation had me looking in on your stuff & has me filing your 4x4 info as a reference to educate myself. Thank you as well
As for a thread/build update, I've been working on it. The driver side brackets are fully welded & cleaned up w/60grit.
I put the 2nd C/O together & did the 2nd trimming on the upper PB Dropmember bag mount for the passenger side. I liked where things were @ so I drilled the holes for the lower mount & the lower arm. I have it all sitting there & today will try to verify the C/O is @ the same angle as the driver side. Then I'll pull the brackets out & get them welded up. The assemble/disassemble process can be time consuming..... and repetitive.
I haven't given it much thought but I'll prob grab one of the various sway-bars I have & do as mock-up for that to while I'm in there. I have an Addco/PB bar that wouldn't work in a different app as well as a ginormous bar (1 3/8" Bell Tech??) I bought for my Dually to test & see if either might work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-10-2020, 03:58 PM   #2
raylube
raylube's Avatar
Your welcome keep up the good work and keep on truckin
raylube is offline   Reply With Quote
