sway bar
thanks for the help in advance.Has anyone installed the CPP front sway bar kit #CPP7423 on their lowered 2wd c10? I tried and the pitman arm hits the sway bar so I switched to the supplied taller brackets on the frame and now the pitman arm is 1/4 inch from the sway bar, I tried taking the spacer out of the end link but the link won't fit back into lower control arm.The instructions were a joke.thanks
![]() Join Date: Nov 2010
Re: sway bar
I just put one on my 69. I have 2 1/2 drop spindles and airbags. I had to use the brackets for non- lowered trucks, ie the taller brackets, and then no spacer on the end links. My end links have only a top washer then rubber bushing, then sway bay then rubber bushing then lower control arm then rubber bushing then washer. If that makes sense. The sway bar is pretty level at ride height and travels from full air up to full air down smoothly.
Re: sway bar
Thank you Bubbasimms that worked.
Re: sway bar
