Old 09-12-2020, 01:54 PM   #1
peglegs
peglegs's Avatar
92 2wd rear axle, what fits
hi folks i have a 92 chevy 1/2 t pick up, 2wd, 342 (41/12 ) gears 5 lug i have a vb knock in the ring & pinion what YEARS & MODELS rear ends will bolt in. i can swap a rear end cheaper than fix the gears. ty stay & safe
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 09-13-2020, 07:14 AM   #2
b454rat
Re: 92 2wd rear axle, what fits
Any 88-up 1/2 ton 2wd. Older axles will work, but may not be same exact width, the spring/shock mounts will have to be moved, and prolly conversion ujoint.
Old 09-13-2020, 07:30 AM   #3
I imagine they will interchange, but the 99 to 2002/2003 rear ends have disc brakes and are 6 lug. But that would mean changing out master and some things.
I would say your probably should look into any 88-98 1/2 for a direct bolt in..
Old 09-14-2020, 05:02 PM   #4
Tom
driving is in my blood
Tom's Avatar
You would have to re-weld spring perches. Its stupid easy to put 99+ disks on a 88-98 axle and keep the 5lugs so the axle swap is actually the harder choice work wise.
OP- junkyard axle time. Just went threw this. Much cheaper then re-gearing if your paying a shop to setup lash and what not. 88-98 2wd all work.
