Old 09-15-2020, 06:05 PM   #1
Aruba1
Best Affordable Headlight ($150 or less)
The stock replacements headlights on my 1972 GCM are a little dim. Even though I plan to clean the grounds, I want to go ahead and upgrade to better lights.
What do you have on your GMC that does good, is reliable and cost around $150 or less? I prefer to stay away from "shiny halo" style headlights unless they are very conservative (no pun intended).
Thanks!!
Aruba1 is offline   Reply With Quote
Old 09-15-2020, 06:38 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Best Affordable Headlight ($150 or less)
First, by all means do the headlight relay mod. That's the only way to get full voltage to your lamps, no matter which ones you end up with.
My recommendation for replacement lamps is unfortunately hard to find and well beyond your stated budget, but their performance is stellar. Cibie H4 E-codes are the best that I'm aware of. Many years ago I installed a set in my '66 Corvette and even with standard wattage, the results were outstanding. Daniel Stern sells them http://www.danielsternlighting.com/home.html and a Google search might locate other, more affordable sources.
Good luck with whatever you get, but be sure to start with the relay mod.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-15-2020, 08:31 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Mike is right about the relay mod. Here is a link to a thread where I posted pics of the difference, with stock headlights. I'd recommend the relay mod, even if you are using different headlights. Notice that even the marker lights in the grill are brighter when the current the headlights draw goes through the relays instead!
http://67-72chevytrucks.com/vboard/s...d.php?t=782071
~Steven
Simi Valley, CA
Old 09-15-2020, 08:42 PM   #4
I have always been perfectly happy with Halogens. I've never felt I needed more once the other (way more expensive) styles of lighting came along. Nice white light.
Old 09-15-2020, 08:49 PM   #5
toolboxchev
Ask around for the ones that Randall at Rtech Fabrications uses and likes. Not 150 dollars affordable but the man has taste. Good taste that is.
toolboxchev is offline   Reply With Quote
Old 09-15-2020, 09:00 PM   #6
68 P.O.S.
Or we could save everyone's time and you can tell us
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 09-15-2020, 09:11 PM   #7
Aruba1
Thanks guys, I am going the Relay way first and look at the results. If I am still unhappy I will be looking at your suggestions. It sounds like the logical way according to this thread. I normally don't like upgrading headlights but mine's are awful :-( although the Bright will wake up the dead, lol.
Old 09-15-2020, 09:24 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Relay harness and Sylvania Silver Star headlights. Done this on three trucks and very happy with the results.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-15-2020, 09:41 PM   #9
SkidmoreGarage
Just want to echo installing dedicated power and ground with a relay, you have no idea what you are missing until you see what 14.4v instead of 11v looks like. I'd recommend a good quality bulb that isn't super bright, the bulbs that are traditional size but " brighter" also die early. I've had a set last less than a year.
SkidmoreGarage is offline   Reply With Quote
Old 09-15-2020, 11:04 PM   #10
jimijam00
Along with the relay upgrade, a set of Hella Vision Plus H4 Conversion, or Wagner BriteLight if you want to stay with a sealed beam.
jimijam00 is offline   Reply With Quote
Old 09-15-2020, 11:26 PM   #11
toolboxchev
Sorry, could not find it on his website, I do remember he speaks of them in his interview with Jay Leno.
I thought he was a vendor of those specific lights. There now I am becoming biased.
Just like my rusted chevy!
Old 09-15-2020, 11:29 PM   #12
toolboxchev
Clean all the electrical grounds on your vehicle, it will wake up the entire system. Mine barely dim running at a stop light.
Old 09-16-2020, 02:59 AM   #13
Richard
Definitely do a relay mod. Plenty of inexpensive 5 3/4" lenses that accept the new halogen bulbs. Here is one I found with just one search https://www.ebay.com/itm/5-3-4-Halog...-/253210370412
Richard
Old 09-16-2020, 11:58 AM   #14
Big Kev-O
Big Kev-O's Avatar
I swapped out my sealed beams to Halogen H4 type bulbs using HELLA 002850811 135mm H4 High/Low Beam Halogen Conversion Headlamp Kit. You will need to install relays to use these bulbs but the results are outstanding. I converted all four High/Low.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 09-16-2020, 01:22 PM   #15
CastIron
CastIron's Avatar
I think GMC low beams just seem dim compared to Chevy headlights because of the smaller diameter. The high beams generally work well though. I have some some Hella H4 conversions and relays for my GMC, but I have yet to install them. I'm confident that they will improve performance though. There is too much volt drop in the original harness/switch.
CastIron is offline   Reply With Quote
Old 09-16-2020, 06:05 PM   #16
bmfm64
bmfm64's Avatar
He may have taste but he has ZERO integrity. I wouldn't let that guy build my worst enemy a go kart.
For the thread- I used Amazon H4 housings so I retain the stock appearing look (not clear, plain glass and no halos or anything like that) and I used the Headlight Revolution H4 bulbs. Literally a night and day difference. The bulbs are a little more than your budget but worth it. The lenses were 20 ish dollars delivered.
bmfm64 is offline   Reply With Quote
Old 09-16-2020, 07:00 PM   #17
gmc684x4
I have hellas in my 72 since dad installed them in the 70s there good for what they are keep looking at retrofitiing a set of hid projectors in a round headlight
Seen prices on them are astronomical
gmc684x4 is offline   Reply With Quote
Old 09-16-2020, 07:37 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Be cautious and research thoroughly before jumping in..... high price is no guarantee of quality, and some HID conversions are junk.
- Mike -
RIP El Jay
Old 09-16-2020, 07:56 PM   #19
Aruba1
That is pretty true, specially when purchasing through ebay or amazon.
With that being said, is there any super doper easy write-up with a lot of illustration on the relay upgrade? I am totally 12v challenged although somehow I was able to wire up my LS, lol
Old 09-16-2020, 08:11 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Start with this, it explains it pretty well. There are other threads too. Search the board for "headlight relay mod".
http://67-72chevytrucks.com/vboard/s...d.php?t=507368
- Mike -
RIP El Jay
Old 09-17-2020, 08:38 AM   #21
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Best Affordable Headlight ($150 or less)
I did the relay upgrade then the H-4 headlights. I also check PicClick to get all the prices in one spot. Amazon has about any type & price range you want for them also.
I bought mine at the car show a few years ago.
I have the LED turn signals hooked up to my parking lights.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
