Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 09-17-2020, 01:20 PM   #151
GOPAPA
GOPAPA's Avatar
Re: What did you do today not on your truck...
When I worked in the sawmill the lumber (boards) were pulled off the green chain and planer chain and put on Jitney blocks and between the rows of boards ever so often to keep the stack of lumber straight and steady to haul away by a lumber carrier or fork truck we used "Stickers" They were rough cut 1/4 inch to 3/8 inch I think ? 4 feet long
A Jitney was a lumber carrier that staddled the loads of lumber and picked the load up by use of the jitney blocks .
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 09-17-2020, 01:45 PM   #152
1976gmc20
Yeah we sometimes just parked the forklift and stacked directly onto it as it was sawed. Mostly it was 6x6x8' for t&g house logs and I stacked them in bunks of 48 with sticks between the rows and then banded it and set it aside to air dry. That sixth row was exercise to get up there for a little guy like me
If the forklift was busy elsewhere like the other crew running the planers then I just stacked the 6x6's on timbers so the forklift could move the complete bunk out of the way.
This was a little bitty sawmill way up in the mountains. The scenery was incredible
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 09-17-2020, 04:46 PM   #153
72c20customcamper
72c20customcamper's Avatar
Trimmed the slider today now I need to finish up the siding.
Just like Tim I try to use azek on the outside of the house . Will outlast me . Had to shim the door 3/4 " over to the right when I installed it this door was smaller than the one I had installed 15 years ago. So I needed to make the moldings symmetrical. Wouldn't look right one 1x6 other 1x8, used 1x8 azek with rabbet cuts for the siding . Got rid of the jmold. Replacing the temp railing and making a platform for the entrance . Little nicer than just steps right into the house
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 04:25 PM   #154
1976gmc20
Cut another little load of wood this morning. I'm trying to get into a routine of cutting a pickup load most every morning after chores until the rest of the semi load of logs is all blocked up and stacked in the yard. A "load" being about level with the top of the bed minus the toolbox and the spare. Just that much green wood smashes down that 1500 pretty good.
I almost need to buy one of those cheap HF hoists that you bolt into the back corner of your pickup bed. Some of these logs are huge and still mostly green. I can hardly pick up the round blocks even only cutting them about 12" long. There's still enough of that log to make about a half dozen more blocks, and that is the big end!
Old 09-18-2020, 04:48 PM   #155
72c20customcamper
This is my latest scrounge of firewood . White oak and hickory I'm in a reall good place for wood dont need anymore but these literally fell into my lap. They are about 20 feet from my driveway across the road .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 04:58 PM   #156
72c20customcamper
I made a log arch for my dump trailer last year . Comes in handy when I dont have the FEL kubota. Basic idea is the arch acts a high point for the winch mounted in front of the trailer . Block and tackle for the wire rope as the log comes up into the trailer the arch swings into the trailer and the log is halfway on the trailer . I then pull the log up all the way with the winch
Able to get wood in less than half the time . The Ambrosia maple in the trailer is now cut into slabs for a table
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 05:29 PM   #157
GOPAPA
GOPAPA's Avatar
What a set up you have there.. tongs and all ..kinda like a jippo logger.. I only got maple a couple times in all my years of cutting my own wood.. great wood to burn
Old 09-18-2020, 05:37 PM   #158
1976gmc20
Yeah, I just block everything and throw it in the pickup. Simple that way. I could build a gallows with the rear stake pockets and use a come-a-long for a lift, but there's not many that big. I had a logging truck with a self loader years ago
Right now I'm working through a 50K# semi load that I bought last fall and had dumped in the sagebrush. It's a 1/4 mile haul to the house. I've gone through all the dry stuff and trying to get the rest blocked and stacked in the yard for winter after next when it will be good and dry, before I go out and start scrounging dead trees from the woods again.
I've got a bunch of misc saw work also: trimming lower limbs and attacking some of the thickets. That gets pretty discouraging because you spend more time dragging and stacking than cutting. Then I bought another 20 acres so that will need some forest management too
80 degrees and smokey today. I ain't doin' saw work in the afternoon.
Old 09-18-2020, 06:47 PM   #159
GOPAPA
GOPAPA's Avatar
Smile Re: What did you do today not on your truck...
Man ,,you are self driven ,,,proud of ya and another 20 acres of it too.. ..I suppose I was too. any time I could get some easy pickens for wood ,,I'd work until I couldnt see anymore ..and right back at it again in the morn...self loading log truck Huh? I couldnt get a boom truck to put up rafters to this 60 ft pole barn I was building and this guy says he'd do it with his self loader,,,,,, ( you know one with tongs and nuckle that swings and twists all over the place ? ) we got er done ,,but talk about doing the hula dance up the ladder trying to catch that darn bunch of steel tryin to conk me in the head was a wake up call to dont do it again .. of course the operator had a lot to do with it ..
Old 09-18-2020, 07:14 PM   #160
1976gmc20
I'm not so driven anymore. I do a load in the morning while it's still cool and that's all. Nice enough weather but it's so smokey that we aren't riding the horses in the PM
My truck & loader wasn't so big: a C/50 and homemade loader. I did have hydraulic grapple but it didn't rotate. The boom had a heel for the butt of the log and that's how I kept it from swinging out of control. Just four valves like a backhoe: main, jib, swing, and grapple. I still can't run a backhoe because I always move the jib the wrong way.
I had to trade everything off when I got sick and went back to school. I heard the GMC and loader got burned up in a forest fire
I bought the other 20 acres mostly to keep anyone from building on it. Also it will make a nice campsite if family or friends visit in the summer. There's even about 200' of seasonal creek down at the bottom end
Old 09-18-2020, 07:26 PM   #161
72c20customcamper
Saws I have an obsession with saws . My usual arsenal going into the wood I have 10 more most old homelites and poulands My little saw 36 inch bar 395xp husky I have a 48 inch for it now
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 07:37 PM   #162
72c20customcamper
One of my ez homies and a 330 never cut wood both run but cant bring myself to put them to wood
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 07:42 PM   #163
1976gmc20
I've got a Stihl so I only need one
And it's 23 years old. When I need a new fuel/oil cap or bar nut, the shop acts like I have an antique I think my old 045 would still run but it got the ethanol sickness. Don't know if there's even parts anymore...?
Long time ago there was a Stihl TV ad (in Alaska, anyway): "I ran over my new Stihl saw with a truck, and I broke the truck!"
Old 09-18-2020, 07:59 PM   #164
72c20customcamper
I have a 460 magnum and a 066 . Stihl saws are great but my Dohlmar 7910 ported, polished,muffler mod with unlimited coil runs circles around them all
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 08:01 PM   #165
1976gmc20
I had an old XL when they were blue. It shook so hard that the handle screws would come loose and jump out and I would catch it while I was cutting.
I think it was a 330 that I bought brand new. I used it about three months in Alaska before something came apart under the flywheel. I got it fixed but it wouldn't run at all at over 10K' ASL in Colorado. For that matter, neither would the Huskies of that era. They would run about ten minutes and then you would have to let them cool off a while. Stihl had the isolated carb so it wouldn't vapor lock.
Then I had two 045's that I ran for years. Always need a spare when you're 50-60 miles from town. I got talked into modernizing and bought an 044. It did okay until I blew it up on a hundred degree day in Montana. So then I bought the 046 and stihl running it today. But I only used it professionally about six months.
Stihl don't like cold weather though. You have to work them really hard to keep them up to operating temperature in the winter. Firewood cutting is okay but falling/limbing they start to sputter. If I was timber falling again, I would run Stihl in the summer and Husky in the winter. Trouble is they don't use the same bars so you have to duplicate everything Doesn't matter since most all jobs is feller-buncher anymore. Sit in a cab and push buttons and look at a computer screen.
Old 09-18-2020, 11:47 PM   #166
57taskforce
All about them K’s
57taskforce's Avatar
Stihl ms290 for me, damn good saw with both an 18” and 20” bar.
I though I was serious about my firewood before these last few posts! Nice work!
Tyler
57taskforce is online now   Reply With Quote
Old 09-19-2020, 11:07 AM   #167
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do today not on your truck...
I went and picked up little red yesterday. My play toy golf cart here at the beach. Got it sitting in the shop right now. Gonna give it a couple days to dry good before I start on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-19-2020, 11:19 AM   #168
LockDoc
The Older Generation
LockDoc's Avatar
I've been working on my 20' x 40' lean-to hot and heavy since the wind storm damaged my barn. Here's a few pictures of the lean-to and the damage to the main support posts in my barn. All 8 of the main support posts are either broken or cracked. I'm not sure whats keeping it up. I thought I would include a picture of the "other" truck with my locally sawn, full dimension 2x8 rafters and 2x4 purlins. They are all from reclaimed power poles. I am now ready for the sheet metal roof.
The '72 Dually has been earning her keep on this one.....
LockDoc
Leon
Old 09-19-2020, 12:11 PM   #169
1976gmc20
So the lean-to is holding up your barn?
I cut another load of wood this morning. Having coffee and a snack right now and planning to go cut another load while I'm dressed for it.
Old 09-19-2020, 01:49 PM   #170
LockDoc
LockDoc's Avatar
I never thought about building the lean-to on the East side of the barn instead of the shop, to prop it up....
LockDoc
Leon
Old 09-19-2020, 06:40 PM   #171
72c20customcamper
Bucked up half of the white oak today . Figure there's around 10k in the trailer by my calculation the trunk was over 15k without the limbs . Going to have to put on the the weight distribution bars the hitch is in the grass . Didnt expect to have this much weight. Only going up my driveway so ya its overloaded
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2020, 07:09 PM   #172
CG
BlahBlahBlah
Made a run to the dump. Also cleaned around my truck so I could see it again.
And my wife is making her version of shoop. House smells great!
Old 09-19-2020, 07:26 PM   #173
CG
BlahBlahBlah
That is so cool! I know nothing about that kind of set up. Sure learn a lot here on the board that isnt 67-72 related. Now Im gonna have to read up on that.
Old 09-19-2020, 07:53 PM   #174
Sheepdip
Sheepdip's Avatar
First look I thought that was a Legends Racer.....Pretty Cool Golf Cart!
Sheepdip is offline   Reply With Quote
Old 09-19-2020, 09:19 PM   #175
TxGary
TxGary's Avatar
Drained the sand out of the sand blast cabinet and filtered out the trash. Good to go again.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
