09-16-2020, 10:12 PM | #1 |
Blinker switch GMC-vs-Chevy
I decided to to install a new blinker switch in the steering column of my daughters 1963 GMC 1500 PU
I am on my third switch from the same vendor and I was told today, it is a Chevy blinker switch, not a GMC, the part will never work. The three new repo switches all had different malfunctions. What I have found all the 1963 Chevy & 1963 GMC pickup have the same wiring (wiring colors and wiring responsibilities). The repo switch plugs directly into the existing wiring System. Anyone ever experience this with the blinker switch ? I feel like I paid good money for this switch and I should not have to take the switch apart and tweak the wire contacts. Has anyone tweeked the inter wire contacts of the repo switches to make these repos work ?
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
09-18-2020, 08:38 AM | #2 |
Re: Blinker switch GMC-vs-Chevy
Mine is new and wont work right either so Iam following to see if theres one that works better or what guys do to fix them. Thanks
09-18-2020, 09:37 AM | #3 |
For me its because I have the Hydramatic Column, NO ONE make a factory or after market replacement, the best you can do is go after market column mounted set up - I did not do that because I don't like the look. YOu can upgrade the column - $$$
http://s1299.photobucket.com/user/jb...23904108567829 |
09-19-2020, 10:12 AM | #4 |
1963 GMC Part number 2440829 is a one year only and GMC only part . Super rare. My only suggestion is replace it with a Chevy NOS 1963 switch GM part number 898197. Or buy your switch from American Autowire. They make the best switch. I was able to do that swap in my 63 GMC but used an NOS GM switch. The aftermarket switches fail and remember , its a 1963 ONLY switch.
https://www.ebay.com/itm/NOS-1963-64...p2047675.l2557
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 09-19-2020 at 10:21 AM. |
