Old 07-10-2020, 08:08 PM   #126
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: ClusterTruck; because that’s what it is
Looking good, you make it look easy. I might try doing mine myself.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-10-2020, 10:07 PM   #127
clay68c10
clay68c10's Avatar
Well thanks. I’ll say that it’s not rocket science, but it’s not a throw together either. There’s a lot of time consuming cutting and fitting, and the welding takes a long time.
I definitely can’t afford to pay someone to do it, so that makes it worth it for me.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-10-2020, 10:22 PM   #128
clay68c10
clay68c10's Avatar
Time wise, this took me about 2 hours after work today.
I still have to fix that front pillar seam, and add a couple plug welds on the front side of the pillar base. Then do the under side welding after the cab goes back up again.
This side fit better than the other, so I’d say for me that 3 hours is a minimum. Thats including the back side welding.
This doesn’t include the rusty pieces removal or the floor/pillar repairs. It really is time consuming.
13 Tahoe LTZ
Old 07-11-2020, 05:45 AM   #129
Ol Blue K20
Looks good though...
Dale
Old 07-11-2020, 09:56 AM   #130
SCOTI
SCOTI's Avatar
I hate the impact of age on my vision. Its getting super hard for me to weld these days unless everything is perfect (which it rarely is). Some good advice given. Keep @ it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-11-2020, 12:20 PM   #131
clay68c10
clay68c10's Avatar
Thanks OlBlue. If you have tools and the time to invest, go for it. I don’t mean to be discouraging, just realistic.
Scoti, after 45 my eyes just aren’t the same as they were in my 30s. I may throw on some readers next time I weld and see if that makes a difference.
13 Tahoe LTZ
Old 07-11-2020, 12:50 PM   #132
SCOTI
SCOTI's Avatar
I'm in my 50's. My lens is magnified & I use readers
Biggest thing that impacts me is welding in different light settings. I get things set-up in one area for the lighting but then have to weld something else in a different spot w/different lighting. Wreaks havoc on my eyes trying to adjust & be able to see the weld path required.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-11-2020, 07:38 PM   #133
Ol Blue K20
Thanks, I may just give it a try.
I found my welding improved slot after I gave up and got prescription glasses. No more magnifying lenses....
Dale
Old 07-11-2020, 09:00 PM   #134
Jason Banks
Jason Banks's Avatar
My vision is ok without glasses, but I find I need my welding to be well lit. I have about a 15 year old Harbor Freight auto darkening helmet that I used when doing almost the same cab repairs you are doing. Then I got a $50 amazon helmet that kept flashing me(aka not working) I finally just got a $215 Miller helmet and I can't believe how much better I can see while welding. Not only does it have a larger viewing area, but it is easier to see when not darkened and much clearer when darkened.
Jason Banks is online now   Reply With Quote
Old 07-11-2020, 11:57 PM   #135
Hogshooter
I like to use a magnetic light to help see the weld seam, I will sometimes mark the seam/hole with soapstone or sharpie. Make sure your cover lenses are new and get comfortable before you start to make things easier.
Hogshooter is offline   Reply With Quote
Old 07-12-2020, 11:51 AM   #136
clay68c10
clay68c10's Avatar
Yes to all of that!
I have a newer auto helmet and it has made a big difference. The view when it’s off is great, and when it’s darkened it’s better than any of my old ones.
Definitely having a good extra light source helps when the lens is darkened. I have a couple of portable LED lights I use and that has probably made the biggest difference for me.
13 Tahoe LTZ
Old 09-20-2020, 03:02 PM   #137
clay68c10
clay68c10's Avatar
It's been a while, I was on light duty for a bit after a collapsed lung. Not fun.
Finally got back at it and finished the rocker back side. Not too exciting, but it’s nice to be done with it.
13 Tahoe LTZ
Old 09-20-2020, 03:10 PM   #138
clay68c10
clay68c10's Avatar
I shot it with some etch primer and a quick rattle can top coat and tipped the cab back to normal.
Now it's time to do finally move my rear body mount brackets so I can mock up the engine and trans fitment. Also I can figure out what firewall holes I'll need and what I'll close up, as well as work on the LS side of the harness over the fall and winter. And any one of the other million things I have left to do...
13 Tahoe LTZ
Old 09-20-2020, 03:16 PM   #139
clay68c10
clay68c10's Avatar
Also flipped my trailing arm brackets to help the pinion angle since I'm lowering it. I had to drill 2 holes, pretty easy job and the same size drill bit as the mount brackets.
13 Tahoe LTZ
Old 09-20-2020, 03:21 PM   #140
clay68c10
clay68c10's Avatar
I got the Hooker/Holley LS stands. They are nicely made and I really like them. They will work with my Speed Engineering headers with some slight trimming to the top of the driver side mount and dimpling the #1 tube (no pic, didn't do that yet).
I usually make stuff like this, but for what they cost it's not worth the fab time to me.
13 Tahoe LTZ
Old 09-20-2020, 03:30 PM   #141
clay68c10
clay68c10's Avatar
I like to move things around with minimal assistance. I needed to get the frame moved into the garage. I used 2 furniture dollies and my son was able to help. Last time I used the cherry picker and a jack and my wife to help. Never again, it was heavy and awkward. This way was super easy.
13 Tahoe LTZ
Old 09-20-2020, 03:36 PM   #142
clay68c10
clay68c10's Avatar
I measured out the center of that garage stall so I don't take up more space than I need.Then I got the frame leveled front to back and right to left. Makes it easier to measure for the 4deg down angle I need on the eng/trans.
It was super exciting to have the TKO bolted up finally. It just looks good sitting there. The green strap worked great to keep everything sideways so I could hoist the whole thing in there from the side. I envy all of you with big shop areas, it makes things easier when you have extra room.
13 Tahoe LTZ
Old 09-20-2020, 03:45 PM   #143
clay68c10
clay68c10's Avatar
The cab is off the dolly for the first time in 2 years. Man it's been a while.
13 Tahoe LTZ
Old 09-20-2020, 03:49 PM   #144
clay68c10
clay68c10's Avatar
If you squint it almost looks like a vehicle, sort of.
13 Tahoe LTZ
Old 09-20-2020, 03:53 PM   #145
clay68c10
clay68c10's Avatar
I was really wondering where my shifter was going to end up. I installed the mid-shift, so I knew it would be in an ok spot, but this really is going to work out well. I haven't measured it, but it eyeballs as 2" to 3" aft of the stock location. I'm happy with that.
13 Tahoe LTZ
Old 09-20-2020, 04:44 PM   #146
SCOTI
SCOTI's Avatar
Nice, big update. Gotta love that amount of progress.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-20-2020, 05:20 PM   #147
doowoppwer
As i read about these LS transplants, I notice that you guys either spend lots of time or money redoing the wiring harness. If a function is deleted from the computer, (assuming the whole enchilada comes from the same vehicle), why is it necessary to redo the harness? I'm thinking in terms of house wiring...if you remove the load and open the breaker, the wire stays in the conduit but causes no problem. Am i missing something critical? thanks.
doowoppwer is offline   Reply With Quote
Old 09-20-2020, 06:57 PM   #148
clay68c10
clay68c10's Avatar
Scoti; yes lots done is nice. Minus my lung situation I would have gotten more done but that’s how it goes sometimes. I’m just happy it didn’t happen out in the boonies, that may not have gone so well.
Doowop; I’m removing a lot because I’m deleting all the auto trans functions. That’s a lot of extra bulk. Realistically a person could leave all the extra wires and just delete the functions from the programming. The only part that really requires wiring work is the power and ground side. But, I do a lot of wiring at work and really want a clean harness so I’m going that extra bit and opening it all up. I’m particular enough that I end up a glutton for punishment with these things.
13 Tahoe LTZ
Old 09-20-2020, 09:47 PM   #149
doowoppwer
Thanks for the reply. I'll be swapping out the tired engine in my daily driver so I won't worry about removing extra wires.
Old 09-20-2020, 10:27 PM   #150
SCOTI
SCOTI's Avatar
I meant to ask.... What/how did the lung thing happen?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
