![]() Join Date: Feb 2009
Bench seat upholstery?
Wondering what's out there upholstery-wise? With some luck I'll need a refreshed seat next year
![]() ![]() My truck had a black seat originally (2nd image). The maker over is ochre/white deluxe, and other than that it's heavily black. Real tempting to put a white seat in there, perhaps leather.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: May 2019
Re: Bench seat upholstery?
Here's my before and after. Had someone locally redo it. Just went with vinyl and houndstooth instead of real leather. Looks good.
1972 GMC Sierra Grande 1972 GMC Jimmy 1949 Chevy Suburban |
[QUOTE=d4hartley;8808279]Here's my before and after. Had someone locally redo it. Just went with vinyl and houndstooth instead of real leather. Looks good.
Nice
Not hard to do yourself I did my 72. USA1 cover and foam from summit as they only charged $20 oversized freight . Saved big bucks on shipping
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Sep 2016
Thanks . I've done a few and what I've found is letting the sun heat up the skins prior to install helps I also use plastic sheeting to slide the cover over the foam keeps it from dragging. When it's where I want it I pull out the plastic. Heat gun also helps with wrinkles. Wish i had a steamer to do it .
Who Changed This?
![]() Join Date: Jan 2013
I need the seat covered in my truck, and am trying to sell the wife on parchment as a color, as the original black brocade vinyl is as hot as Satan's skillet when the truck is sitting in the sun. I don't care that much about original, at this point.
![]() Join Date: Jul 2015
Agree
Wholly seat covers, check these out https://www.ebay.com/i/274242291728?...xoC8CsQAvD_BwE Don't know how long this link is good, if you can't get to the item click "original listing" and scroll down. Nice seats, but more than that you will appreciate his shop https://www.ebay.com/itm/67-72-Chevy...p2047675.l2557
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-16-2020 at 12:46 AM. |
![]() Join Date: Dec 2013
I've been buying parts from Ebay member jlfab118 for a while now , He's close . Has free shipping and everything I bought was shipped fast . His windshield and rear window gaskets are Precision brand I just bought a rear large window with trim gasket to cut down for my small window 67 and it was $42.95 shipped . He has some good prices
![]() "Don't know how long this link is good, if you can't get to the item click "original listing" and scroll down. Nice seats, but more than that you will appreciate his shop" https://www.ebay.com/itm/67-72-Chevy...p2047675.l2557
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Total cost was around $400 but I'm sure the prices have gone up in 2 years . The cover was top notch and is holding up well I've put 25k on the truck since install . The foam is a little stiff even after 2 years not uncomfortable but raised me up to where I had to lower the seat . Took me about 3 to 4 hours to recover the seat
I had a local upholstery shop make new covers, repair a football sized area of the seat foam, and hog-ring the coverings on. The estimate was not much more than buying new repop coverings. AND, I got to get away from the vinyl. I went with tweed, but stuck pretty close to the original patterns. I'm not going concourse correct so the savings was well worth it and saving my wrists from the hog-ring pliers is a good thing. I expect to pay about $400. Here's a sneak peek as they are almost done with the job...I'l be picking it up this week. Leather was an option, but outside my budget.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#13 | |
#15 | ||
Thanks Grumpy
