Old 09-24-2020, 03:03 PM   #1501
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Wow! That looks fantastic. Great save.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-24-2020, 03:54 PM   #1502
rowdy11
Nice work! Where did you purchase your windshield? Locally or ordered and shipped?
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 09-24-2020, 04:20 PM   #1503
pjmoreland
pjmoreland's Avatar
I tried ordering a windshield from Summit, but they were backordered for two months out, so I bought one locally. Paid $140 for it. I'm a little annoyed that it is made in China, but that's the way it goes these days. At least it has a nice green tint.
pjmoreland is offline   Reply With Quote
Old 09-26-2020, 11:59 PM   #1504
TxGary
TxGary's Avatar
Assembled my new bed,
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 09-27-2020, 12:10 AM   #1505
pjmoreland
pjmoreland's Avatar
Replaced the rear main seal and oil pan gasket. Had to contend with a snapped off bolt the PO left for me. Bought a right angle drill from Harbor Freight to access the hole because it was right above the cross member. Hammered a Torx bit into it and fortunately it unscrewed. I felt like I won the lottery when that happened. The PO also used RTV on the entire rear main seal, so I had to make a scraper to very carefully clean out the passageway above the crank.
Old 09-27-2020, 02:11 AM   #1506
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My hood was paroled. All I did is write a check.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-27-2020, 11:58 AM   #1507
72c20customcamper
72c20customcamper's Avatar
Looks great
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-27-2020, 01:22 PM   #1508
davischevy
davischevy's Avatar
Sometimes checks are good.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-27-2020, 02:19 PM   #1509
basketcase
basketcase's Avatar
I have the wiring mostly completed and getting things buttoned up.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 09-27-2020, 05:07 PM   #1510
Mts67C10K20
Mts67C10K20's Avatar
Today I repaired the broken studs on my turn signal housing
Ang gave them a good scrubbing
Mts67C10K20 is offline   Reply With Quote
Old 09-27-2020, 08:00 PM   #1511
72c20customcamper
Ya I keep writing checks my body can’t cash . Started on the drivers side rot today
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-27-2020, 08:03 PM   #1512
CST10
CST10's Avatar
Changed my electric fuel pump on ol Samson, it was a pain to get to inside the frame rails with the exhaust but it’s done now.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 09-27-2020, 10:10 PM   #1513
pjmoreland
pjmoreland's Avatar
Finished replacing the heater core. Installed the inner fender and hoses.
Old 09-28-2020, 12:13 PM   #1514
jsprengeler
jsprengeler's Avatar
Those heater cores are a ***** to get out! Any tips/secrets you could share?
Incapable of not thinking about my truck at least every other minute
jsprengeler is offline   Reply With Quote
Old 09-28-2020, 12:31 PM   #1515
pjmoreland
pjmoreland's Avatar
It sure was a lot of work. I'm not sure I did anything unique on this repair. I followed various pieces of guidance I found from searching the forum. I used pieces of wood to support the hood while the hinge was removed. I removed the inner fender (I had already removed it to do some rust repair and paint). I had a hard time separating the heater box from the firewall because the previous owner had glued it on there with an excessive amount of RTV silicone. I purchased a copper/brass heater from npdlink.com based on lots of comments about the aluminum cores not fitting. I purchased a heater box seal set from GMC Paul's and glued the round seal and air box seal to the air box with weatherstrip adhesive.
Old 09-28-2020, 01:20 PM   #1516
OregonNed
OregonNed's Avatar
Set up for a new carburetor install. Area ready
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-28-2020, 01:44 PM   #1517
tdangle
tdangle's Avatar
Finally changed throttle out to a cable. Decided to add some bling, deluxe pedal assemblies while I was at it. And new floor mats to try and hide the hole in the carpet left by the floor mounted pedal
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-28-2020, 02:31 PM   #1518
basketcase
basketcase's Avatar
I got lucky with mine. The truck was all apart when I got it and had 3 cores and housings
in the boxes. One tested good and was an easy install with the whole front end off the truck. I hope I never have to go back in there.
Tom
Old 09-28-2020, 05:33 PM   #1519
72c20customcamper
Drivers side kick my butt today . I’m used to having the passenger side worse than the drivers it this was a farm truck. So I guess all the slop ended up there. Made all the patches myself most likely would have been harder with aftermarkets also put two coats of pour 15 on the passenger side.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-29-2020, 05:26 AM   #1520
OregonNed
OregonNed's Avatar
Looks great!
Old 09-29-2020, 05:01 PM   #1521
ohboy321
ohboy321's Avatar
I rented a hot power washer and de-greased the drive train and engine bay. PO's did not have a functioning PCV system and oil was misting everywhere. Now I can finally proceed with my engine update project!
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 09-30-2020, 07:30 PM   #1522
Peanut74
Did some touch up painting and painting some miscellaneous parts. I went ahead and installed the fresh air inlet doors
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 09-30-2020, 09:55 PM   #1523
BC10
BC10's Avatar
Installed Redhead power steering box. Can't wait to take it on the highway.
BC10 is offline   Reply With Quote
Old 10-01-2020, 09:38 AM   #1524
72c20customcamper
I'm going to have to rent one of these. Need to do the 68 and in the past I've used ezoff and just my garden hose. Worked well but I haven't been able to find any oven cleaner in several stores . They've been sold out for weeks guess there's been a rush on even cleaners too
Tried engine cleaner but it really didnt work at all. The gunk stuff they must have changed the formula
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-01-2020, 06:10 PM   #1525
72c20customcamper
Today’s fun been a long road with this 68 . It’s all in primer now
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
